Coin Tray
Coin Tray
How do I remove the coin tray in a 03 TLS? I have a little too much change in it and a dime got lodged in the back of the coin tray, making it hard to open. I just need to know how to take it out cuz I don't wanna break anything. Thanks guys!
I recently had work done on my 2002 and they messed up the coin/ash tray in reassebling the dash. To fix it he had to tear apart the dash again. Not a good thing. To make matters worse that springy toungue thing came out again. Arghhhh.
![Dunno](https://acurazine.com/forums/images/smilies/dunno.gif)
its not hard but you basicaly have to take apart the center console to get the coins dislodged and the ones that fell behind it
Is there a DYI about tearing apart the center console and removing the coin tray? I know, I definately need to invest in a Helms. Thanks again guys!
EDIT: I meant DIY...damn acronymns!
same problem here, freaken coin is stuck somewhere behind the coin tray, a DIY would be nice
ummm, coins will not be attracted(pulled) to a magnetic charge, but good try
Sig Rho's Finest
Originally Posted by teknoking
ummm, coins will not be attracted(pulled) to a magnetic charge, but good try ![Smile](https://acurazine.com/forums/images/smilies/smile.gif)
![rofl](https://acurazine.com/forums/images/smilies/rofl.gif)
![pofl](https://acurazine.com/forums/images/smilies/pofl.gif)
http://www.abunchofcars.com/diy_page...er_console.htm
there's your DIY for removing the center console
Thanks! So on that site, does the coin tray come out along with the center console? Or which step do I stop at on that site? I'm not trying to remove the deck or anything. Thanks again tpatel.
Sig Rho's Finest
to get the coin tray section out you need to get until step 19. its all pretty easy except removing the seat heaters. Thats a HUGEEEEEEe pain in the ass cus the thing is like 4 inches long and you have 4.1 inches to work it. its real tight. try jiggling the coin tray around a little. this happened to me and after i played with it, it came down enough to push down the silver metal clip inside and remove the tray.
thanx, a lot of work, im lazy. lol
whats the point of Step 9 and 10? how do they affect the coin tray area?
oops, nevermind, i just looked inside the car, Step 9 and 10 are needed, lol.
ChairmanMaoSaysRTFM
it's really not that bad. i can take the whole console apart in about 10-15 minutes now. but i've also done it a few times to install my radio. just use a little flathead eyeglasses screwdriver to get the seat heater controls out. i never had a problem. just switch it to the "lo" position and you will have an opening to stick the screwdriver in.
do not remove the cupholer. those 4 screws hold nothing else in but the cupholder.
just the two inside the console storage, about 6-8 holding the console onto the trim, one behind the drivers kick panel for the trim, one on the passenger side for the trim, two by the EEC diagnostic port (HINT: use a telescoping magnet from autozone to hold onto the screw while you turn it, or use a magnetic screwdriver, both are cheap and will make life easy!)
once you remove the heater controls and the ring around the shifter it's pretty easy. i wrote a more detailed post on this once. try searching for it under my name and maybe you'll find it.
SSTS
SSTS
mlody
12-04-2019 02:11 PM
09-25-2015 06:14 PM
