Coil-Overs......
Old May 31, 2001 | 02:36 PM
Question Coil-Overs......
I was woundering does anybody have coil-overs on their TL....or do you know anybody who wants to sell there....i've heard that the TL and the V6 Accord are the same in most mods....will an Accord coil-overs fit on a TL?
Old May 31, 2001 | 02:46 PM
SinnedTL's Avatar
Ain't No Other...
Post
yes a 98 and up v6 accord springs and coil over kits should fit.
Old May 31, 2001 | 02:59 PM
snook789's Avatar
Post
Acura TL Coilovers
Old May 31, 2001 | 05:13 PM
BlackShadow's Avatar
O.G.
Post
I have the Apexi Coilovers for my TL.
Binh
Old May 31, 2001 | 05:15 PM
GIMMICK's Avatar
Post
I have the same Apexi Coilover for my Accord.
Old May 31, 2001 | 06:06 PM
[VTEC]TL's Avatar
RWD convert
Post
I have Ground-Control Coilovers on my TL.
Old May 31, 2001 | 06:55 PM
Post
Hows the ride?....is it easy or hard to lower and higher your cars....and how much did you guys pay for installation?
Old May 31, 2001 | 11:53 PM
Post
Yeah, is the ride better than if you just install comptech springs...or is the only main benifit the ability to adjust the height?
Just curious, dont know which mod would be better for the ride.
Old Jun 1, 2001 | 01:17 AM
O.G.
Post
I don't know how the Comptech springs ride but the Apexi Coilovers ride pretty smooth (close to stock). The ability to adjust is a major plus especially living in the NE because of the bad winter. All I have to do is turn the tire and stick my hand in and rotate the screw inside.
If you got the $$$, then go for the coilovers. Mine cost @ $860. Because with the springs, you have to purchase shocks too. Then it will add up close to the price of the coilovers. But with the coilovers, you can adjust them and the springs you can't. Hope this helps.
Old Jun 1, 2001 | 03:58 PM
mchtypeS's Avatar
Post
i have nex suspension on mine
2001 cl type s
voltage blue, comptech headers, 18 inch ssr agle strusse rims,(painted voltage blue and achrome polished lip) custom iceman intake, pioneer avx 7000 tv, playstation 2, slammed on nex suspension, cross drilled rotors, nos fuel pressure regulator, greddy evo exhaust, (on the way level ten torqe converter and b&m tranny cooler) april 16 taking car to dealer getting 3.5 liter upgrade(mdx crankshaft, mdx rods, shaved heads, port and polish intake manifold, modified dome topped pistons.compression ratio 10.85:1
http://albums.photopoint.com/j/View?u=1335581&a=9936626&p=46258064&Sequence=0
Old Jun 1, 2001 | 05:04 PM
GIMMICK's Avatar
Post
I heard that the Tein's will be available end of this year/early next year. They've actually prototyped it on an Accord Coupe and will be available as part of their CS line (Comfort Series). There's a discussion about it over on SHO V6 accord forum, I'm just relaying the info here.
Old Jun 1, 2001 | 11:17 PM
Talking
Thanks ....was it easy to to adjust the coilovers.....like did you have to jack it up just to get to da coilover? Thanks again
Old Jun 1, 2001 | 11:22 PM
j83's Avatar
j83
Wink
i dont think you have to jack it up unless you have it way low, but with 0-1 inch gap you can probaly get under there.
Old Jun 2, 2001 | 04:08 AM
SL1200MK4's Avatar
Post
I think Tein is available, NOW!!! But I don't think it's the CS series, They have the NA kit for Accord and our TL. I asked the guy at the autoshow but the price is... let's just say a bit high for me...
