Code Reader
Old Oct 4, 2007 | 08:46 PM
dukat111's Avatar
5th Gear
Code Reader
Hi,
Can someone tell me where the plug for the code reader is. Either I'm blind or it doesn't look like what I'm expecting.
Thanks!
Old Oct 4, 2007 | 09:05 PM
fsttyms1's Avatar
its under the "not an ashtray" Remove the little plastic cover under it and it will revile it
Old Oct 4, 2007 | 09:26 PM
dukat111's Avatar
5th Gear
Thank you so much!!! I'd never have found that.
Unfortunatly it says, "No faults detected".
My SRS light went on, i replaced the fuse, disconnected the battery and tried the code reader with no success.
Old Oct 4, 2007 | 09:59 PM
Gfaze's Avatar
S E L L
Your basic code reader is not going to be able to read SRS light codes. Usually it has to be a high-end diagnostic scanner ($$$) or a specialized scanner made for SRS diagnostics.
Old Oct 5, 2007 | 07:04 AM
fsttyms1's Avatar
^ correct.
Any tampering with power to any of the srs components will cause the light to come on
Use this to reset the light.
http://www.geocities.com/myintegra96/srs.html
Jamus22
Jun 11, 2023 10:08 AM
MilanoRedDashR
Oct 2, 2015 10:49 AM
thegipper
Sep 28, 2015 01:01 PM
shawnafoxx
1G RL (1996-2004)
Sep 28, 2015 12:33 PM
mars
Sep 28, 2015 11:03 AM
