Code P1457
Code P1457
Had dealer use diagnostics for check engine lite and came up with P1457. Toldthis is short in bypass valve 9lots of corrosion). Rec replacing that valve, the 2-way control valve and evap canister to the total tune of about $540. States he highly doubts the ECM is shorted as well but does not know until does above repairs(states that in unlikely event that is case could be another $1K). Other than for the lite on in dash the car runs great('03) with 87K. Anyone run into this situation?
check these for some more info/suggestions
https://acurazine.com/forums/showthr...ighlight=P1457
you can always speak with a service MANAGER who probably does know about cars and can explain things better
'service writers are there to write the original order and call you for increase approval
Jamus22
06-11-2023 10:08 AM
