clock question
Old Nov 17, 2010 | 08:29 AM
NJoba147's Avatar
clock question
alright so i got my 00' two years ago, and since i got it there was no back light to the clock. im just wondering if the clock originally doesnt have a light or if the owner before me never replaced it?
Old Nov 17, 2010 | 08:41 AM
niju321's Avatar
the backlight burned out, i think there is a diy for bulb replacement in the DIY sticky, otherwise search for clock bulb replacement and you should find some instructions
Old Nov 17, 2010 | 09:45 AM
-Double Dee-'s Avatar
haha i have the saame problem!! i changed it to led and it still doesnt work... so i dont know
Old Nov 17, 2010 | 01:56 PM
soria's Avatar
Did you try turning the LED 180 degrees? I think they have a polarity. if its positioned the wrong way it wont turn on.
Old Nov 17, 2010 | 02:09 PM
V_Langs_3.2TL's Avatar
Rice Patrol
Mine burned out years ago, It hasn't been worth it to me to take apart the dash to replace it.
though an LED would be nice, if you don't have ANY Leds it'd be a bit off if only that one light was led
Old Nov 17, 2010 | 02:28 PM
totaledTL's Avatar
You don't have to disassemble the dash. It's pretty easy, about 15 min.
https://acurazine.com/forums/2g-tl-problems-fixes-117/dash-clock-light-out-621510/
Old Nov 17, 2010 | 03:53 PM
Rice Patrol
uhh based on the DIY (i've read that one before) you take the entire dash out.
yeah it can be done quickly, but the dash still has to come out of the car...
Old Nov 17, 2010 | 04:31 PM
AlanW's Avatar
2006 NBP TL MT6/ 02TL-S
burned out back lights
I don't know what it is about these cars, but when I bought my 02TLS about 2 years ago, I had to replace over 1/3 of all the back lighting bulbs in the dash, instruments, & switches.
I'd take a good look at everything and order & replace all that need it at once.
Old Nov 17, 2010 | 05:18 PM
03tLsNBP's Avatar
MechEng
no need to take the whole dash out, just pull it back and reach in with a screwdriver to change the bulb. ive done it several times.
Old Nov 17, 2010 | 06:15 PM
Sperry's Avatar
2000 TL Black on Beige
It's daunting the first time, if you've never taken apart a dash.
However, it is not too hard, and bulb replacement gives you a great sense of accomplishment.
Small hands make it way easier to unplug a few cables, allowing the dash to swing out a little further.
Old Nov 17, 2010 | 07:04 PM
soria's Avatar
Its 2 screws above the gauges. Then everything else is clips. Work your way around with a screwdriver while gently prying it out with your hands.
***Use a flat screwdriver covered with tape to prevent scratches***
Old Nov 17, 2010 | 08:32 PM
totaledTL's Avatar
That's simply untrue- you do not have to remove the dash. Just trim & clock module if I rem. correctly. It doesn't take very long.
Old Nov 17, 2010 | 09:10 PM
Rice Patrol
maybe our definition of dash is different. in that case, i'm sorry
Old Nov 17, 2010 | 09:48 PM
soria's Avatar
What you guys are referring to is the "dash trim". totaledTL thinks you mean the whole dashboard.
Old Nov 17, 2010 | 10:06 PM
yea i did that and still nothin, i changed all my dash lights to leds, it looks great!! and its not that hard only took a hour or two.
navtool.com
3G MDX (2014-2020)
32
Jan 20, 2016 11:43 AM
navtool.com
31
Nov 16, 2015 08:30 PM
Skirmich
Oct 1, 2015 12:59 PM
95oRANGEcRUSH
Sep 25, 2015 12:50 PM
2Quik
Sep 23, 2015 01:03 PM
