Climate control...
Porkchop Sandwiches!
Climate control...
I was wonder is there a way to adjust/calibrate our climate control systems? Maybe its just because its cold out but when im driving and I have it set to like 61 - 65 it still blows fairly warm air out, when i turn it down to 60 it blows really cold. Does anyone else have this problem? I know we have one temp sensor by the driver in the dash, does the climate control also use the outside temp sensor for its adjustment?
here is the owner book link for you. The outside guage is just that- has no relation to the inside temp, and its real intent was to warn the driver when temps are near freezing so you watch for ice on the road.
https://techinfo.honda.com/rjanisis/...01_OMANUAL.asp
Gotcha, altough i feel that when its warmed the climate control definately behaves differently. I have Mitchel on demand install on my dad's computer at home im gonna do some research.
Also unfortunately those PDFs on the acura site dont work with Macs. Not even with abode installed i think, even though every mac user just uses the built pdf viewer anyway.
Its always a game of chance with these "temp controlled" systems-
one car I set at 80 for 5 minutes then turn it off, the TL gets set at 70 and hope~
The TL has sensor on the dash and another by the driver right knee on the panel.
Running thr AC or Defrost will screw with it, having a window or moonroof open will change the airflow inside....
blacktsxwagon
Oct 27, 2015 10:12 PM
Rob144
Sep 21, 2015 08:18 AM
