Climate control
Climate control
this issue has been bothering me and wonder if anyone has a solution for it. the climate control is totally off, fresh air is flowing in. now i hit the mode bottom so that i can change from which direction the flow is coming from. then i would like to increase the air flow. but you can't operate the fan unles you hit the 'auto' button or the 'ac' button. and in either case the ac compressor kicks in. i would like to increase the fan control without turn on the compressor first. anybody every notice this?
So you're saying you want the Fan blowing but without A/C right? if you hit A/C button (not auto) it turns the A/C off and on. And you just use the right knob which controls the fan blowing speed. Is that what you wanted?
![Confused](https://acurazine.com/forums/images/smilies/confused.gif)
no, not quite. lets say you are cruising on the highway and you just have fresh air coming through the vent. the fan is not on. the climate control screen just shows the vent mode that it's blowing out at your face and feet. it doesn't indicate whether the ac is on or off or the temperature.. just the vent mode. at this point the fan control is not effective. for the fan control to work, you either have to hit auto or the ac button. and once you do the compressor kicks in. then you have to hit the ac button again to turn off the compressor but now the fan control works. my gripe, i guess, is that i can't use the fan control unless the the compress has to kick in.
it's probably confusing unless you try it.
Yea, I've noticed this, When i'm on the highway even though the fan is off, I feel air coming in from the vents. My guess is that you cannot control this because it's just the air flowing throw open vents. If you hit the button then the real AC or Climate control kicks in.
Re: Climate control
Originally posted by hzm82
its not grinding noise for me......its a slight hum, its the motor moving the vents. Try turning on air circulation on and off. It makes the same noise.
I don't really care about my noise, just don't want it to fail completly when I am out of warranty....
Vijay, well in your case if you don't want the air to come in then put it in circulate mode instead of fresh air mode. in my case some times i want a faster flow of fresh air. and i can't just turn up the fan control, i have to turn on climate control for the fan control to work.
i am assuming that the other noise you guys hear is that of servos redirecting air flow from head/feet, feet/defrost type of deal.
noise
When I turn my ignition on, if Climate Control is set to Auto, there is a loud buzzing nois under my deshboard. VERY annoing. Sounds like actuator motor without lubrication. So I will be talking to my dealer about it soon. You probably have the same noise...
Originally posted by Strannik
noise
noise
adreano17
09-29-2015 08:48 AM
