Clicking Sound During Turns
I have noticed this problem recently about 2 weeks after installing comptech sway bars on my 2000 TL. Whenever I am making a sharp RIGHT turn either from stop or at low speed I hear a SINGLE clicking/snapping sound coming from the front passenger side near the windshield area. Has anybody else experienced this or any idea on what may be causing it?
I have a clicking noise that sounds like it is coming from the passenger window or wheel well. It happens when my front passenger wheel hits a bump or the car sways. I think it is the plastic trim in the moonroof area. I'm going to the dealer in 3 weeks.
If it's related to the sway bar install, check the end link nuts. Mine got a little loose after a couple of weeks and cause a slight clicking noise when I stop or start. Just grab a 14mm wrench and tighten the nuts.
Here's a link to some pics I took of the install which shows where the nuts are located.
2000 Acura 3.2 TL (Nav)[*]Comptech Springs & Sways[*]Home Depot Grill
there are quite a few posts about this if you do a search, but the outcome has been that it's the swaybar hitting the frame and it just needs to be adjusted. that's probably what yours is too.
here's my topic from a while ago for more details on what I experienced.
http://www.acura-tl.com/ubb/Forum1/HTML/007044.html
<A HREF="http://www.adamoski.com/acura.html" TARGET=_blank> </A>
mada51589
05-03-2022 08:54 PM
cak165
1G TSX Problems & Fixes
09-16-2015 08:17 PM
