cleaning the tranny solenoid
tightnight (12-19-2012)
Chapter Leader (Southeast Region)
Oh yeah that one is like 250$ if I remember correctly that's the torque converter lock up solenoid. I would just replace the third and fourth gear pressure switches and change the fluid
Hey Tightnight, what kind of shifting problems are you experiencing ?
As Stephen00TL suggested, a drain & fill using Honda fluid would be advisable....along with a new filter. When pulling the shift solenoid switches, inspect them for residue. Also check the drain plug for fines. You may want to consider having the fluid analyzed for contamination.
Good luck
How was the fluid level and overall condition. Was the fluid dark and smell burnt ?
Did the drain plug have a build up on it ?
