Cleaning Comptech Air Filter
i was handed down a comptech oiled filter and it was very dirty. i wanted to find out how to clean it. would a k&n recharge kit do the trick???
thanx...
thanx...
Not a Blowhole
NO! You can pretty much use any cleaner (wheel cleaner works well), but the oil should be a hi-tack oil designed for foam filters.
It has to stick and also saturate to ensure it does not load up with water. I would stick with Uni-filter oil to be sure - this is not something to scrimp on unless Comptech says it is ok.
Purchased: April 28, 2001
I've never cleaned a filter in my life. As a matter a fact, the last time I saw my filter, only 1 side of it was dirty, so I just rotated it 180 degrees. As for cleaning it, I'm not too confident of what a decent job would be, so I might just go out and buy me another replacement filter.
Originally posted by paultl
does the comptech drop in filter offer any performance gains compared to OEM filter?????
Not a Blowhole
systek: No means no. I said no to the K&N oil unless Comptech or Unifilter says YES. Where do you get it? From Comptech or Unifilter!
You can clean the filter with Simple Green.
http://www.unifilter.com/caremaintenance.htm
Try this Systek..
Goto a motorcycle shop (like Yamaha, Honda, etc.) and ask them for the cleaner and oil for an aftermarket foam (Uni) filter. Basically Uni makes the aftermarket air filter for motorcycle/dirt bike usage.
If you need further assistance drop me a PM, or e-mail. The Uni filter cleaning stuff is suprisingly cheaper, and more quantity than the K&N cleaning supplies.
Re: :(
Originally posted by JSuppi
I tried
I was actually doing a search on the recommended procedures to clean a K&N cone filter and ran upon that thread Oops.
I tried
Abe_Froman
09-16-2015 01:27 PM
