cigarette lighter holder attach ?
Old Apr 4, 2016 | 02:30 PM
lsiravi's Avatar
The cigaretty lighter in the dashboard next to the coin box in my 2003TL works but is somewhat loose - it wanders in and out and doesn't stay stable in the dashboard hole. How does that power receptacle attach to the hole, and how can I make it stable? Would this be an easy fix?
TIA
Old Apr 4, 2016 | 02:34 PM
Mine was doing the same thing. Never got around to fixing it prior to trading it in.
I imagine you can remove the side panes & it probably has a threaded nut that holds it on, that has likely backed out over time.
But, looking at the parts diagram, I don't see what I'm describing:
Not sure if #3 is threaded onto #2.
Old Apr 6, 2016 | 07:58 PM
totaledTL's Avatar
Did this a few weeks ago. Remove 2 screws in bottom of center console compartment. This allows you to move the console a bit so it's easier to remove right side trim (#13) & right panel (#12). Then you can reach the threaded collar (#3) that holds it.
Just be careful, take your time, & use plastic or nylon pry tool so you don't scratch anything.
Old Apr 8, 2016 | 06:30 PM
lsiravi's Avatar
I should/will give it a try. Thanks, folks. At least I will open up the panels and take a look in there.
00TL-P3.2 - yes it does seem a little unclear.
totaledTL - So the collar is threaded? The collar turns and tightens against the holder itself?
Thanks.
Old Apr 9, 2016 | 07:41 PM
lsiravi's Avatar
Got this thing done with today. Basically what totaledTL said - the collar is threaded and attaches to the lighter thing.
Additionally, I also found $13.01 ;-) in slightly sticky and corroded coins under there and under the carpet. There's a few more coins left over but aren't accessible. I don't remember losing quite so many coins down there, possibly the previous owner did...
Rob Ryckle
Apr 11, 2016 03:00 AM
04SSMnMD
Apr 4, 2016 12:55 PM
z643167z
Mar 14, 2016 02:25 PM
anotherng
3G MDX (2014-2020)
Mar 3, 2016 04:00 PM
