Check Engine Light + TCS Light (Constant Problem)
'06 Acura TL
I have a '99 TL w/ 73K and last year my check engine light & TCS light went on...I came to this forum and solved the problem by simply removing the fuse for the clock and putting it back in...
This problem has happened at least 3 times in the past year...& I can solve it by simply removing the fuse for the clock and putting it back in, but i'm wondering why is this happening? Is there some underlying problem that I don't know about and the remove/insert clock fuse is just a temporary fix?
any input would be great
the first step would be to pull the code when your check engine light is on. Autozone will do this for free. Then it will be easier to narrow down your problem
^ Exactly. Next time its on get the codes read. When those lights com on it means the ECU is reading that something is wrong. Its designed to get the owner to get the car fixed. Get the codes read and we can help you figure out how to fix it from there
'06 Acura TL
Going to autozone now to get the codes....ill post em when i get back.
Thanks guys
& no my tranny has not been replaced.... i hope thats not the prob...i have no $$$
Thanks guys
Originally Posted by VQPower37
has ur transmission been replaced? ... if not it could be that since i believe tcs light is one of the major symptoms of tranny failure ... just a guess
'06 Acura TL
Code: P1491
Definition: EGR Valve Lift Insufficient Detected
Probable Causes: 1-Poor Electrical Connection 2-Failed EGR Valve
What does this mean?
Clean your EGR port and EGR. There is a DIY in the DIY thread.
'06 Acura TL
based on that DIY it seems that my Acura is still covered under the extended warrenty...considering it seems like alot of work taking everything apart i rather just bring it in...will they cover it?
'06 Acura TL
Yea I think I'm 6 months out of warrenty based on the 80K 8Year policy for this recall...hopefully they will clean it out on goodwill & consideration. I'll call my dealership tomorrow & bring it in.
'06 Acura TL
o how i hate acura....i call them up today and my car is 6 months out of the extended warrenty for clogged egr valve...i ask him about doing it under goodwill and he said it was based on the maintenance of your car and since my timing belt needs to be changed he would do that and clean the egr valve at no charge...of course the timing belt to be changed is $900!!! So now I don't know what to do....I'm probably going to wind up paying just for the EGR vavle (1.5 hrs labor) and then change the timing belt through my mechanic when it desperatly needs to be changed.
'06 Acura TL
called the other dealership near me...there gonna confirm the problem and then ask acura for compensation(goodwill) so maybe i won't have to pay for it after all. we will see when i go in tomorrow morning.
Just do it yourself. Its not hard and on a scale of 10 its a 1.5. Its easier to do than changing plugs.
'06 Acura TL
i wouldnt go as far to say its my fault for not handling the situation when it happened....i came here when the lights came on and was told to take the clock fuse out which happened to fix the problem (over & over again)...so i didnt know there was another problem...i dropped my car off today...there gonna call me after they diagnose it
'06 Acura TL
i wouldnt go as far to say its my fault for not handling the situation when it happened....i came here when the lights came on and was told to take the clock fuse out which happened to fix the problem (over & over again)...so i didnt know there was another problem...I looked at the DIY & its way to complicated for me...im studying to be an accountant not a mechanic
i dropped my car off today...there gonna call me after they diagnose it...
Hopefully the dealer gives you good news.
All the way to redline
But here is a question that just popped into my head. Why did you come in here trying to get help when you were not going to try to fix it yourself? fsttyms1 was kind and directed you to step by step DIY and then just blow him off. Not only did you waste his time but ignored his helpful advice.
'06 Acura TL
well i would fix the problem myself if its not complicated...after looking at the DIY it looks very complicated....I didnt ignore his advice i just chose a different route...in any case i use this forum & everyone is very helpful here & i thank u all...I Love my acura & never want to get rid of it!!!
edit: & i didn't pay to have this fixed...like i said there gonna "take care of it" another words FREE
2000 Acura 3.2 TL (185K+)
my car does the same thing. its def the ECU. i ahve had misfires and i need to change my O2 sensors, so maybe u could check your sensors?
i had the same problem as you, you need to make sure whoever fixes the EGR valve knows WTF they are doing. I had mine fixed by my dealer friend 3 times, spent over 500 bux, still no luck, TCS and EGR would still come on. I finally took it to Acura and after the fixed the EGR, i never saw the engine light or TCS again, plus they warrantied their work.
Last time I checked, OBII code reads were free. at Acura and at Autozone. Why not take it in for that the first time around? and if it is something you know, or have an inkling of an idea that it might be under warranty, take it in.
THEN, if the dealer tells you to screw off, come back here, and figure out a way to fix it.
This way you don't waste another persons valuable time for your SOUGHT after advice.
'06 Acura TL
wrong....acura dealership charges $105 to diagnose problems (aka hook it up to the check engine code reader)...& I'm not wasting anyones time.
Well, I have taken mine to both places for free. If not the dealer than try autozone, they usually let you borrow specialty tools (like code readers) if you have your drivers license.
I took mine into the dealer because of a trouble light, they ran the code and then left me at the option to buy the new part or drive away. Don't know why they wouldn't do the same.
Might have also been because I had just finished forking over a grand for a new rear windshield the week before???
mada51589
05-03-2022 08:54 PM
rockyboy
01-25-2016 06:00 PM
