Cheap Performance mods for a 1999TL
7th Gear
Hello, i have a '99 3.2TL and was looking for performance modifications that are on the lower cost side. Also, if anything can boost performance and boost fuel economy, that would be great. I have been thinking about a cold air intake but what one is best for my car? Also, anyone have knowledge on performance chip?
Thank you, Nick
Thank you, Nick
Usually people will do CAI and pulley?
remove most of the seats? I think that can improve the mpg.
And change the tires to thinner type, like the civic does.
7th Gear
Well I have also thought of sway bars as well but i am looking for some things that can make the car more efficient while also making it perform better. Budget wise, not that i have it but, goals and such so i'd say Up to $1000.
7th Gear
Well the air filter wasjust replaced at the Acura dealer,I only run Premium, plugs were just installed at the acura dealer and i am seeing only about 15 mpg. I drive pretty carefully but maybe i am somewhat of a lead foot hahaha. But aside from that i am looking at a Comptech Icebox and Tsudo Axleback for performance. For the hell of it, i may just replace the plugs and see if it helps.
99 NBP tl
Tsudo Axleback is not going to give you anything noticeable performance wise, I have them and I think they are great for sound and looks, but if you want performance then your best bet would be a full exhaust like the ATLP exhaust, although those run around $1000 (i think).
do a search there are a million topics on begginer mods for this car. there are however no such thing as cheap 'performance' mod. even a full catback exhaust wont give you much results without less restrictive headers. There no ecu reflashes for the car and CAI are usually pointless and only for sound. read this:
https://acurazine.com/forums/showthr...1#post13772753
my best bet would to buy a 02-03 type-s and have it supercharged (comptech supplies one i think)
if you are keeping a none type-s i recommend investing on brakes, tires and suspension, not much further the engine can go unless you spend nearly 2k on atlp catback and better headers. even then you would only gain ~10hp and much improved throttle response. for the suspension, good brand name coilovers and thicker front swaybars would be the way to go. all my cars have upgraded more rigid sway bars because i do not want to compromise ride comfort (stock spring/shocks).
stangkid64 (05-13-2012)
Unregistered Member
Mmmkay, so no one really gave you any pertinent information yet.
I would start off with a CAI. Since you have a 99TL, you should get the AEM V2 CAI. It is the best CAI for our cars, but it doesn't fit the Type-S models. Gains are only about ~5hp, but this will increase as you add other mods. Most importantly, this will make your car sound much more aggressive. This will run you about $250.
Next up should be headers. I would recommend DC headers, and they will give you about 25hp. These are the best bang for the buck. They will run you about ~$300.
If you want a deeper sounding exhaust, I would recommend the Tsudo axlebacks. They won't give you any HP gains, but they will make your car exhaust note sound much deeper. I believe these are about ~$250, but I could be wrong.
Next up is a lightweight crank pulley. You can get an underdrive Option pulley for about $30, or get a stock sized UR pulley for about $200. Obviously the Option pulley is a lot cheaper, so I could go with that if you're on a budget. Gains are about 8HP.
I would go in the order of items I listed. You should skip the exhaust if that's not your thing. Also, I would space out the time between the mods, so you can see what you like.
7th Gear
Okay, so basically i should forget about anything that will boost noticable power and just things that will make the car more stiff and better handling? I am down with that. Although, i like those Tsudo's cause they sound GREAT. I cant afford to buy another car at this point as most Type-s' are going for around $8000 around here where i live and a supercharger must be crazy money. Now, i think i will look into tires, wheels (better looking then stocks), and suspension. Thanks for the help guys!
7th Gear
if u really cared about gas you wouldn't have bought a TL in the first place.
But if it means a lot to you you can always remove your intake resonator for free and gut it. i used to get 24 mpg, and after i removed my intake reso and cut it open i got 26 MPG, pretty awesome for a free mod. sounds amazing at vtec, but also swallows a lot more gas lol
Unregistered Member
well it happened for me, i always calculate my MPG everytime I go to the gas station. I know it's surprising, but it actually happened to me. I used to get 24.something, now I get about 26.something. I drive the same way as I always have and do a the same amount of driving on the freeway.
Unregistered Member
There are probably other factors that you may not be aware of. However, gutting the resonator alone will give almost zero gains, in both HP and MPG.
There are MANY other factors that affect your mpg, and a combination of them probably helped you. For example, mpg will change according to seasons and temperature. Even the gas changes seasonally.
http://en.wikipedia.org/wiki/Confirmation_bias
Look at it strictly scientifically. It's just not possible. The designers of the car would have better designed the intake resonator if it was cutting 2mpg. If they could get the sticker mpg to be 31 instead of 29 by a simple redesign, they would have done it.
lanechanger
10-13-2015 10:56 AM
joflewbyu2
10-08-2015 11:16 AM
ExcelerateRep
Sponsored Sales & Group Buys
09-22-2015 10:39 AM
