changing tranny fluid
Old Jan 2, 2007 | 01:41 PM
phuster's Avatar
when you use the drain bolt does it drain out 3 quarts automaticlly or do you have to measure the 3 quarts out?
Old Jan 2, 2007 | 01:47 PM
cjde2006's Avatar
it is a little over 3 qts. I think I put in about 3.18
Old Jan 2, 2007 | 05:28 PM
fsttyms1's Avatar
thats all that will come out
Old Jan 2, 2007 | 10:38 PM
superfob's Avatar
Only three quarts come out because theres still tranny fluid trapped in the torque converter.
Old Jan 3, 2007 | 01:29 AM
01tl4tl's Avatar
Has anyone tried either a home unit or a shop based oil vacuum system?
The shops advertise 100 percent fluid replacement because they can suck the torque convertor dry.
Old Jan 3, 2007 | 10:16 AM
fsttyms1's Avatar
Honda doesnt want/like complete flushes like that. just do a drain fill
Old Jan 3, 2007 | 02:56 PM
01tl4tl's Avatar
Thanks Kris
After I put some break-in miles on the new trans I will be doing a switch to synthetic
TL
Old Jan 3, 2007 | 03:59 PM
jperdoch's Avatar
Where is place to add the fluid ? I used to change mine on my 88 Legend and just refilled via the dipstick tube ...
Old Jan 3, 2007 | 06:47 PM
dward's Avatar
7th Gear
You could use the dipstick to refill....I took out my oil jet to refill mine...this thread may shed some light...
https://acurazine.com/forums/showthread.php?t=150293
However, mine is an '03 with the oiljet recall....not sure if you have that or not. If not, you should see the refill plug on top of the tranny...
Good Luck,
D
Old Jan 3, 2007 | 08:21 PM
jperdoch's Avatar
Good Luck,
D
thanks - I had the oil jet installed, so that thread works for me !!!!
Old Jan 3, 2007 | 08:54 PM
fsttyms1's Avatar
Thanks Kris
TL
amsoil would be the only thing i would stick in it if i did
Thru the oil jet hole is the fastest and easiest
Old Jan 4, 2007 | 07:36 AM
Luke7's Avatar
WNC Real Estate Sales99TL
Solution=always measure the amount of fluid that comes out and refill with the same amount then check the level. Simple solution eh?
Old Jan 4, 2007 | 07:40 AM
Luke7's Avatar
check out this post too=more info and ramblings
https://acurazine.com/forums/showthread.php?t=148630
Old Jan 4, 2007 | 12:35 PM
fsttyms1's Avatar
Thats what i do
Old Jan 4, 2007 | 06:37 PM
01tl4tl's Avatar
Gotta agree with Luke and Kris. Measure and replace. On my old Chevy truck (no easy drain plug)- used to haul the race car, we disconnect the oil cooler line and do a "hot flush", pouring in as we remove, not something I would ever do to my beloved TL!
Thanks to Kris I now understand to use synthetic oil only in the engine and muffler bearings. The transmission gets the Honda fluid it was designed with
Old Jan 4, 2007 | 06:41 PM
fsttyms1's Avatar
Yes gotta take care of those muffler bearings!!!
Unfortunately the TL 00+ (well i believe teh 99 does) doesnt have coolant lines that you can do the hot flush (ive done before as well) unless you have installed a tranny cooler. Then its possible to do so, but i would stick with the drain plug method
Old Jan 6, 2007 | 08:05 AM
elliottk1's Avatar
ATF filter(s)?
All my prior experience has been with GM and Chrysler automatics, where a fluid change ALYWAYS included replacement of the rather large FILTER that is accessible after dropping the bottom pan. Looking at the Helm/Honda shop manual for the 99 TL, I don't see any reference to a filter anywhere, although online suppliers list a "torque converter filter" as a replacement part.
While just changing 3 qts of fluid now and then is a good idea, if there are filter(s) in there gradually becoming plugged ...... Is there an accessible filter that can be changed easily in the TL 4-speed?
Old Jan 6, 2007 | 08:36 AM
fla-tls's Avatar
On the way!
That hot flush that you describe does the exact same thing that a modern flush machine at a transmission shop does. It usually takes about 14 to 20 quarts to "flush" an average transmission.
The cost of 14 to 20 quarts of Honda Z1 or Amsoil fluid???
I'm a big fan of the triple drain and fill....
Old Jan 6, 2007 | 08:38 AM
fla-tls's Avatar
On the way!
No. You have to remove the transmission and split the case in half to get it out.
Old Jan 6, 2007 | 08:49 AM
elliottk1's Avatar
Hmm. Another high-consequence-of-failure item that's designed to be non-maintainable or extremely expensive to maintain (see timing belt) .....
Old Jan 6, 2007 | 09:04 AM
fla-tls's Avatar
On the way!
I don't agree at all. Honda transmissions kinda work like this...
__fluid in pan___ -> Filter -> Pump -> Internals -> Solenoid screens -> ___Fluid in pan___
The fluid that goes into the pump (through the filter) is clean, however, components within the transmission break down and release particles. These particles build up on the solenoid screens and cause shifting problems, etc.
The root problem is that something in the internals is breaking down - not that the solenoid screens are clogging (so cleaning solenoid screens or changing the solenoids will not provide a long term fix). If the transmission is functioning well, this breakdown should not occur in the first place.
As you can see, changing the filter does not stop the process from occurring. Honda transmissions can routinely go over 200k miles if they are well maintained, have no manufacturing flaws, and are not abused.
The Honda setup - with a non-replaceable filter - is just fine. The only way a Honda filter will get significantly contaminated is if something is going wrong with the unit in the first place. Even then, the filter has a tremendous capacity to hold contaminants and lack of fluid will generally not be a problem.
People frequently get cause and effect confused when it comes to transmissions.
Old Jan 6, 2007 | 09:19 AM
elliottk1's Avatar
Acknowledged. But since normal wear on parts will result in production of some fine particulate (whether from clutch packs or other surfaces), even without actual component failures, it would be expected to find some deposits on any filter in service for a long time period.
Since the filter is in the fluid flowpath to critical component(s), it follows that the fluid flow to these components will be diminished somewhat over time, albeit slightly. Granted, if the filter is entirely plugged, it's probably associated with a catastrophic failure requiring a rebuild anyway.
Bottom line, if there's a need for a filter in the first place (in any system, not just the AT), it seems that it would be prudent to be able to access and clean/replace that filter. Just my personal preference. But I'll guess that Honda has calculated that normal wear over X thousand miles should produce particulate of Y amount, which will result in filter/screen plugging of Z percent, which will not diminish hydraulic or lubrication performance for something in excess of 100K miles. Periodic partial fluid changes will carry out whatever particulate is in suspension in the fluid, but of course can't remove anything that's already deposited on a screen or filter.
But I'll keep dribbling out my 3 qts and replacing them periodically, and hope for the best.
Old Jan 6, 2007 | 10:05 AM
fla-tls's Avatar
On the way!
Wet clutch systems like that in an AT put out almost zero particulate. If they are working correctly and have regular fluid changes, a transmission with 100k miles will look basically brand new inside. That's why fluid changes to a well functioning transmission are a good idea - no buildup to flush out, and you replenish the additives in the fluid.
Unfortunately, the clutches will start to put out particulate when they start to burn from slipping (which is caused by any number of root causes - some preventable, some not). The high detergent content in the fluid simply carries away the weakened oxidized clutch material from the pack. If it gets really bad - it's not just clutch material anymore. It's now also metal. That's why fluid changes to a transmission that's already got problems are a bad idea. That built up gunk gets washed out into the rest of the transmission and can clog many things beyond filters. The worst one I saw was actually a clogged cooler. The filter still allowed sufficient fluid through, but the clogged cooler caused an overheat condition.
I've only seen one vehicle that had a significantly clogged filter this year. Unfortunately it was a comeback for our shop on a heavy duty truck where we put in a torque converter with a defective lockup clutch. The clutch simply came apart without slipping. The clutch was sucked into the filter and caused a low pressure situation. Again, the root cause was not the filter being clogged - it was the defective clutch.
I understand the desire to think, "There's a filter in there. I need to change it." In the case of Hondas, for the most part I'd put my bet on the engineers that designed it. They know what they are doing. It's one hell of a robust design (OK - maybe not on some TL's ).
Old Jan 6, 2007 | 12:06 PM
elliottk1's Avatar
Thanks for the input.
Old Jan 6, 2007 | 12:08 PM
fla-tls's Avatar
On the way!
You're welcome. Welcome to the forum.
mugen_kid
Nov 13, 2015 10:38 PM
fifer16
1G RL (1996-2004)
Oct 16, 2015 08:54 AM
ghuns
Sep 16, 2015 04:26 PM
Aleax
Sep 11, 2015 11:31 AM
HeloDown
Sep 8, 2015 06:51 PM
