Changing Engine Oil
Old Jan 11, 2007 | 11:10 AM
acutee's Avatar
Changing Engine Oil
Will changing engine oild using the oil suction canister pump through the engine oil dipstick be efficient? or Is it better to drain it through oil pan drain bolt? Thanks
Old Jan 11, 2007 | 11:14 AM
phipark's Avatar
Not Asian
Using the pump is sufficient, but it's probably best to use the drain bolt.
Old Jan 11, 2007 | 02:09 PM
acurabum's Avatar
Why do you want to use a oil suction canister pump ???? You might suck back up to the engine all the dirty partical and you do not want to , right !
Use the oil drain plug .
Old Jan 11, 2007 | 04:56 PM
acutee's Avatar
the hose will go through the oil dipstick tube, straight to the oil pan, so I don't think the particles will get back to the engine. Anyway, I think using the drain plug is better route since particles on the bottom of the oil pan get flush when you drain it, I guess.
Old Jan 11, 2007 | 05:21 PM
rjheiss's Avatar
You'll need to under the car to change the filter...so why bother with the pump??
Old Jan 11, 2007 | 06:31 PM
ChrisQ1980's Avatar
hates the winter
Exactly. I always pour in a quart of low quality synthetic with the bolt off to get the extra crap out. It comes out dirty at first, then clean.
I say do it the right way, not the easy way.
mada51589
Jan 9, 2025 04:40 PM
Laoch
1G RL (1996-2004)
Oct 2, 2015 03:27 PM
pizokk1
Sep 17, 2015 09:29 AM
Aleax
Sep 11, 2015 11:31 AM
merc009
Sep 3, 2015 01:44 AM
