changing corner light bulbs
Old Aug 22, 2004 | 10:09 PM
shawn744's Avatar
Kollage is funn!
Hey guys, quick question, do you have to remove the headlight assembly to change the corner light bulbs?....going to get these silver bulbs:
http://www.hidking.com/silverseries.htm
is there anywhere for cheaper/easier?....and which one of those do i buy, there's two item numbers. thanks. -shawn
Old Aug 22, 2004 | 10:32 PM
goldendragon576's Avatar
TL-S driver
no, you do not have to remove the whole headlight. depending on which side your changing, turn your wheel the opposite way so you have the space to get into the wheel well. The rest is pretty easy, take the clips out and the whole lining should pull to the side, the light is right there, twist and pull out and that's it. Good luck!
Old Aug 23, 2004 | 09:36 AM
shawn744's Avatar
Kollage is funn!
hey neighbor!, didn't notice you're from NM til just now, i've got family there, i was there yesteday actually....cool.
oh you have to get at it through the wheel well....okay- what do you think about the lights? (website)
Old Aug 23, 2004 | 10:24 AM
Tatewaki's Avatar
not the best solution IMO. I have some $2/pair clear bulbs (no coating at all) to replace the amber bulbs. They are clear so once installed they are almost transparent in front of the chome housing. They lit up in a somewhat orange/yellow color next to the HID so the cops won't bother you
Old Aug 23, 2004 | 10:29 AM
shawn744's Avatar
Kollage is funn!
do you guys know the part number of those corner lights?
mada51589
Jan 9, 2025 04:40 PM
voigt
Sep 2, 2015 10:44 PM
bymotion
Aug 31, 2015 05:00 PM
Mcj270
Aug 31, 2015 04:45 PM
ptbarnett
3G RLX (2013+)
Aug 30, 2015 12:39 PM
