changed my plugs and now no gas mileage
Hi guys - thanks for reading.
Simply put i have a 148,000 miles and i just changed my plugs for the second time around. I put in the NGK ix as recommended and i immediately went fromn getting 360miles a tank to 280miles a tank. no check engine lights, car runs smooth, nothing but gas mileage . what gives!
whats wrong with the install? coil not on tight?
someone found 1 ngk not gapped right recently when they had a problem
cant tell anything from 1/2 tank--its abou the total miles travelled on x gallons of gas
have you seafoam or similar cleaning of the internals yet?
oh yeah i love me some seafoam. it was a full tank as well - 280 miles when just the tank before i was at 360 miles. car seems to run nice and smooth , no misfires or anything.
since 1940- and its garbage?--maybe when you're older you will understand the dynamics involved
your right. Please tell me all 49 years of your seafoam experience.
I'd love to know it so i can one day use it with full confidence.
Seafoam is dumb because there are so many things that can go wrong.
Just take care of your motor by doing proper maintenence intervals and oilchanges.
you should not have to disconnect the battery and force an ecu reset just for new plugs
but if the old ones were toast--what did it have for plugs and miles?
Since you have issue with seafoam- which I did use in a pro shop in machine and now out of a can for my car--then product of your choice IS maitenance
You may need to clean the TB plate- you dont have a problem with that do you?
and the plug gap was checked in case you are the 2nd in a million plug that had one off?
I got the same reaction when swaping to Iridium plugs .... mileage went sud .
Did you notice any other different in car performance ?
I put back the olds originals Double Platinum plugs and every is back to normal ...
Go figure ................
The Dumb One
Ah..
ive run only 93 octane or more in my cars since i started driving.. oil changes every 5 k.. and fluid flush 2 times a year... it doesnt matter what you do... gunk will build up in your engine.. regular upkeep is NOT enough. and i'd probably listen to somebody twice your age about cars.. you might be suprised...
for anyone concerned are iridiums good-???
just buy the stock dbl plat NGK and be done with it
The rest of us wiki'd iridium and learned how much better it is-
without marketing hype
OculiAquilae
11-19-2018 02:24 PM
