Changed Engine Mounts-- Damaged Transmission?
Old Jul 23, 2014 | 04:20 PM
slowboat's Avatar
Hey guys. Car is '99 TL, 200K miles.
I finally took the plunge and replaced the rear motor mount. It was original and I was told by a couple shops that it was bad. The car jerked more than normal when putting it into reverse and shifting was not silky smooth as it used to be.
I found a DIY on here and changed the rear mount without removing the bracket. I loosened the mounting nuts on the front mount and the 2 trans mounts as not to stress them when lifting the engine. Upon lifting, I saw that the 2 trans mounts were nearly broken so I replaced those too.
I had some trouble with the front trans mount. However I finagled it, it would not fit in. I continued to jack the engine higher to provide more clearance. I realized I had the mount in backwards! When i turned it around, it was clear that the engine was jacked up very high-- about 1-1/2 inches higher than necessary for clearance for the trans mount.
I put everything back together and went for a test drive. Reverse was fine but when I put it in drive, the car barely moved. It feels as if the transmission is partially in neutral and only 1/2 of the power is going to the wheels. D3 does the same, but gear selector in 2 and 1 move the car as normal.
Did I damage the shift cable between the gearshift and the trans by lifting the engine too high? Or worse?
I pulled the clock backup fuse and disconnected the battery to reset the ecu and the problem didn't go away. Check engine light and traction control lights are on.
Old Jul 23, 2014 | 04:37 PM
ErickUa5's Avatar
Mr.Helpful Diagram
Hook up a scanner to see what codes you'll get.
Maybe the range sensor wires got crushed or something, Just taking a wild guess.
Old Jul 23, 2014 | 05:08 PM
sounds like you have pretty good idea on what could be wrong.
if nothing else, I know it's a pain, but, I'd jack the car and engine back up to investigate.
Old Jul 23, 2014 | 06:50 PM
slowboat's Avatar
ErickUa5 I like your suggestion. I know someone who is a tech and can probably borrow his scan tool and pull the codes.
mada51589
Jan 9, 2025 04:40 PM
Aleax
Sep 11, 2015 11:31 AM
Mike Bertram
Sep 10, 2015 09:27 AM
HeloDown
Sep 8, 2015 06:51 PM
Papa Roe
4G TL Problems & Fixes
Sep 1, 2015 09:41 PM
