Cel p1710
Old Jan 17, 2009 | 07:20 PM
veo's Avatar
veo
Cel p1710
My check engine light came on.Code p1710. Anyone know what this is? Thanks for your help.
Old Jan 17, 2009 | 07:27 PM
fsttyms1's Avatar
I dont see a 1710 in the manual but any thing 1700+ is trans related. DO you still fall under the trans warranty?
Old Jan 17, 2009 | 07:33 PM
veo's Avatar
veo
i just bought this car used so i dont think i have any warranty. I saw transaxle when searching the code so you are right that it is trans related.
Old Jan 17, 2009 | 07:46 PM
newperson's Avatar
There's no Acura in
What year is your car & how many miles?
Old Jan 17, 2009 | 08:13 PM
veo's Avatar
veo
2003 with 160XXX miles
Old Jan 18, 2009 | 01:29 AM
fsttyms1's Avatar
Being a 2003 your probably not in the covered vin range, and with the miles your out side it. Odds are you have a trans failure coming up. Do you notice any harshness going into gear or any minute slippage between shifts (most noticeably the 2 to 3 shift)
Old Jan 18, 2009 | 07:55 AM
veo's Avatar
veo
no harshnass or slipage.Everything feels smooth right now but I will pay close attention to 2 and 3 shift. I still have to find out the exact problem for code p1710 so I can fix this before any trans failure.
Old Jan 18, 2009 | 10:17 AM
FISHYTL's Avatar
p1710 is a problem in 1st-hold Switch Circuit on the transmission gear selector
Old Jan 18, 2009 | 04:53 PM
veo's Avatar
veo
does that mean i just needto replace that switch?thx
Old Jan 20, 2009 | 12:38 AM
FISHYTL's Avatar
here are the instructions to properly diagnose the code.
http://uploading.com/files/85SD40HY/1710.pdf.html
I hope that helps. How come we cant upload files to acurazine?
Old Jan 20, 2009 | 06:15 PM
veo's Avatar
veo
Old Jan 20, 2009 | 10:24 PM
FISHYTL's Avatar
I just looked over the pdf again and part of step 6 got left out. Here is the rest of it.
YES - Repair open in the wire between PCM connector terminal E14 and the 1st-hold switch.
NO - Go to step 7.
Old Jan 27, 2009 | 06:15 PM
veo's Avatar
veo
thx
Old Sep 1, 2016 | 04:43 PM
Jersey201's Avatar
5th Gear
2003 MDX p1710
2003 Acura MDX code p1710 having problem with trans 1 and 2 shift Slip sometimes when I floor the gas pedal how I can fix this problem ?? Anyway
Yikes
May 3, 2021 04:29 PM
heykosal
1G RDX DIY & FAQ
Nov 16, 2020 03:59 PM
NJALLDAY57
Oct 13, 2015 08:25 AM
samson_420
Oct 8, 2015 01:47 AM
hrothgar02
Sep 28, 2015 11:08 AM
