CD stuck in player
Old Sep 23, 2004 | 11:00 AM
TypeSDragon's Avatar
Loving my 08 TLS!
CD stuck in player
I am getting an ERR-01 on my 6 indash cd player. Looks like a cd is stuck in there. Anyone has experience on fixing this??
Old Sep 23, 2004 | 11:26 AM
BiggyMcWang's Avatar
USDM UA5 A-Spec
I had this problem too... I was worried I had to go back to dealer to fix it... but managed to fix it myself. What happend to your CD player is the rack got unalligned. In my case I saw the CD visibly but it wouldn't come out.
I took the CD i radomly grabbed and starting gently pushing... actually gently pressing the jammed cd in the tray and releasing a few times. There is no way you can physically remove it from the tray without the CD player ejecting it. after about less than 3 presses i heard the CD changer motor running again and close the loading slot and play the CD all over again. Total time was 2-3 minutes. I guess luck but maybe you can try also. I'm definitely doing the same thing again if it were to happen again. Good luck.
Old Sep 23, 2004 | 02:34 PM
Professor's Avatar
Карты убийцы
Same problem... CD player was replaced under warranty.
Old Sep 23, 2004 | 03:17 PM
Head Wanker
Yep, same problem and had it replaced under warranty. The service guy mentioned not using CD-Rs with labels because they are too thick and will jam the mechanism in the changer. Since then, I only use my old school audio CDs. If I got back to making my own mixes, then I'll leave out the label.
Old Sep 23, 2004 | 03:22 PM
fla-tls's Avatar
On the way!
Me too - replaced under warranty. Got the CDs back about 2 months after they replaced the unit.
Old Sep 23, 2004 | 05:53 PM
Yep..very common. I'm on my 3rd player. I cringe everytime I hit the eject button.
Jerry
Old Sep 23, 2004 | 05:56 PM
Dai's Avatar
Dai
Well, this just happened to my player the other day although the little door was shut so I couldn't see the disc or anything.....also, it told me there was no # 4 disc, but I know for a fact that it was the # 4 disc that got jammed.
Anyways, called the dealer and my warranty expires a couple of months ago so it wouldn't be covered. booo....read up a bit more on this error and someone suggested banging on the side of the centre console (drivers side) and it worked!!
Banged on it a couple of times and the disc dislogded itself!!!
Old Sep 23, 2004 | 06:06 PM
indoMFP's Avatar
What your problem is?
I had a cd stuck in the system, and I just slid a cd in it and the cd slid right out....
SidhuSaaB
May 30, 2020 12:40 AM
Jul 16, 2017 07:33 AM
Fool
Mar 10, 2016 08:42 PM
