CD jammed in 6 disk :(
FvCK KNvCKLE
Any one have to deal with this?
I'm very handy, and am not affraid of taking the head unit out and getting in it to remove the stuck CD. But if it's a big hassle, I'll let the dealer handle it.
It's right in the middle somewhere too... As far as the unit is concerned slot 6 is empty. But it won't play any other disk with out coughing up an "ErEl" error.
Can you even see the [stuck] CD? Mine usually get stuck when they are trying to eject [unsuccessfully] and I can see it in the slot thru the open door. The only CDs that get stuck are the ones with labels that I applied. Usually I can insert a small, flat screwdriver and free it.
FvCK KNvCKLE
Originally posted by NOVAwhiteTypeS
rock, did you by any chance make a custom cd label for the cd that's stuck? cuase this happen to me once too.
If you can see the disc in the opening but it just won't come out, you can take another disc and press its edge to the edge of the one jammed in the player and gently push backwards. This should push the disc in enough to force the motor to retry and eject it. As a last resort, you can also take a pair of needlenose pliers and reach in and grab the edge of the disc and *gently* try and pull it forward and out. WANRING: You may damage the disc doing this if the pliers scrape the outer edge of the disc. I'd consider this a last resort. You can also try pressing and holding the "eject" button until it displays "EJEC" on the display. This forces it to spit out all six discs. Again, I would only try this as a last resort if you think it is jammed internally. If you've tried everything else and are going to have to take it to the dealer anyway to fix it, it can't hurt to try a couple last-resort techniques.
i too could not get a cd to ejet from slot 6 one but it wasnt a custom made cd...it was a cd from korea, a real one...and now my after i got the cd out, the cd changer won't recognize any cds in slot 5 or 6. taking my car in to have it replaced. had anyone else have to replace there stereo? oh..also i've never used the little shade thing that slides out from the front shades....well the other day my friend pulls it out on the passenger side and now it wont slide back in....
calrow
05-03-2017 10:21 PM
handsom-hustla
11-13-2015 05:04 PM
travr6
09-06-2015 02:11 PM
