Car stalling while driving
Old Jun 26, 2013 | 08:00 PM
Karanx7's Avatar
Unregistered Member
Hey guys,
I recently took off my IM to clean it out, and to clean my IACV.
Since then, my car has stalled while driving randomly. I'll just be cruising along, and I notice the battery and oil lights are on. Then I realize the engine actually just turned off.
So while ~40mph, I just press the clutch and try to start the car again. The starter tries for a little bit, and eventually it will turn on.
The second time this happened, I pressed the throttle a bit while turning the engine on. The car started and then revved, but it sounded like an electric toy spooling up. Very strange noise. Then went back to normal.
Could it be a bad fuel pump?
Old Jun 27, 2013 | 07:20 AM
3.2TLc's Avatar
If you suspect that it may be the fuel pump, have the fuel pressure checked.
But, if this just happened after the "cleaning", recheck your work. Maybe it's something vacuum related, IDK ???
Old Jun 27, 2013 | 08:52 PM
Karanx7's Avatar
Unregistered Member
I think it's just my A/C compressor acting up. Coincidence with the cleaning.
Old Jun 28, 2013 | 12:12 PM
webmastir's Avatar
2003 TL
Follow up where if you end up figuring it out. Curious myself..
Old Jun 30, 2013 | 03:00 PM
tlmane03's Avatar
Originally Posted by Karanx7
Hey guys,
Any other/new details describing what happens? If I come across any info that sounds related will let you know bro. If it aint broke dont fix it
Old Jun 30, 2013 | 04:46 PM
Karanx7's Avatar
Unregistered Member
I'm pretty sure my A/C compressor clutch is failing. The refrigerant was low for ~3 years, so the compressor probably didn't have enough oil.
When I press the clutch, the RPM dropped all the way to ~700rpm, and the A/C compressor kicked on and just killed the engine.
When I start up the car again, I can hear the A/C compressor winding up. It almost sounds like a turbo lol.
peti1212
ILX
22
Jan 5, 2022 05:14 PM
Feb 25, 2020 09:57 AM
divac
Aug 29, 2018 10:13 AM
kuzdu
Sep 10, 2015 08:42 PM
Aug 30, 2015 02:39 PM
