Car is overheating
Old Sep 11, 2018 | 07:34 PM
deepconcentratn's Avatar
Car is overheating
OK Acurazine family, I got a problem with my car and I hope someone can point me in the right direction.
My 2000 TL is overheating. Let me explain whats strange to me about the whole thing.
No coolant loss
Both fans come on
Condenser fan comes on with A/C
New Radiator. New Radiator cap
Top and bottom radiator hoses hot
fuses good. Relay good
Here is what I can't figure out. Why does the temp keep going up? The fans pop on for a second but the temp keeps climbing. Fluid levels are good.
Now here is what I noticed. When I park the car the radiator fan comes on for about 10 minutes. I know the fan is supposed to come on but this is different. Its almost immediate. As soon as I turn the car off, the fan kicks on immediately.
Fan Switch? Thermostat? Both?
Old Sep 12, 2018 | 04:37 AM
Iggy's Avatar
Did the problem start after you replaced the radiator? Why was the radiator replaced? Did you follow the burping procedure?
I would suspect air in the system. Drain the system into a clean bucket and try refilling it "slowly" with the fluid you just drained. Follow the burp procedure.
Here's a vid:
Old Sep 12, 2018 | 06:35 AM
frankjnjr's Avatar
IMO: Agree with Iggy, but what I don't understand is why the fans come on immediately after shutting the car off. Since the cooling fans appear to be doing what they are supposed to do, this would seem to be an indication that the engine is running hot, in general! Unless it is extremely hot,"ie" 98-105 ambient, the fans in my 03 TLS rarely come on after shutting the engine down. Possibly a faulty thermostat, but, as Iggy says, "burping" the system properly is very important. I'm also curious as why the radiator was replaced in the first place, and or what led up to it's replacement.
Old Sep 12, 2018 | 06:57 PM
The radiator was leaking. I was taking my son to school one morning and I noticed that my car was smoking like crazy. I pulled up the hood and there was antifreeze coming out the top part of radiator. I changed it for that reason.
Old Sep 12, 2018 | 07:07 PM
Here's a vid: https://www.youtube.com/watch?v=zUpXgAJ1gjU
I bought the radiator on 8/10/2018. Ironically, I noticed the problem on 9/10/2018. So exactly a month after I installed the radiator, I started noticing my car overheating. Do you think an air bubble will last that long without the car overheating.
Old Oct 23, 2018 | 06:36 PM
Yo Iggly
Yo Iggy. I got that Spill Free Funnel and it worked like a charm. Thanks for the info
Old Oct 23, 2018 | 07:33 PM
Iggy's Avatar
ohgeez1224
Nov 16, 2009 06:22 PM
Silver Si El Es
Aug 3, 2008 01:03 AM
18anatak
Oct 3, 2005 10:53 PM
BLaCk Acc
Nov 1, 2004 02:12 PM
Black TL
May 3, 2001 02:02 AM
