Car Leaking Help
Old Mar 8, 2004 | 02:34 PM
eyesnake02's Avatar
Angry Car Leaking Help
Today i went to class and i pick up my back pack from behind the driver seat and it was all wet. I started to feel the back driver seats floor and the floor was wet then I went to check the driver side floor and it was also wet too. I was wondering if this has happen to anyone before? how did water get in my car? I only have 9000 miles on it so its pretty new.
Old Mar 8, 2004 | 02:44 PM
njtls's Avatar
is it like soaking wet or just wet?...could be water from your feet...or passengers feets...
Old Mar 8, 2004 | 02:58 PM
Turboara's Avatar
was it raining? maybe you left the door open a bit, or a window open a bit
Old Mar 8, 2004 | 03:09 PM
FidizzyTypeS's Avatar
Thermostat could be busted...that'll leak water into the car.......maybe a door seal is bad.
Old Mar 8, 2004 | 07:02 PM
bigdaddy-fl's Avatar
piss anyone off lately? j/k. probably just left a window open. it sounds like a lot of water to be coming in from a bad door seal.
Old Mar 8, 2004 | 07:54 PM
Or.....sunroof drain plugs could be clogged, causing water to leak inside the car.
Old Mar 9, 2004 | 01:09 AM
Like a mideget on a moped
i dont know why i just thought of pull ups! I'M A BIG BOY NOW!! YAY!!!
Old Mar 9, 2004 | 05:21 AM
whoopidoo's Avatar
2002 TL-S
This is likely your problem. Before my 02 TL-S, I had an '88 Acura Legend. I had to have the sunroof drains cleared every 18 months or so, as gunk would grow in there and prevent them from draining properly, causing the floor under either seat to get soaked.
The dealer (or most any shop) can clear them for you, likely under warranty. You'll definitely want to get this done, and have them get the water up with a shopvac or whatever or you'll end up with mildew in the carpet.
Of course, my car was 15 years old with 200K+ miles and saw a lot of wet summers. Yours only has 9K miles - seems like a short time for these to clog up if that is indeed the problem....
Old Mar 10, 2004 | 09:09 PM
Unless the car spends a lot of time under trees, where leaves and other things can accumulate........
I agree, though, does seem early.
Old Mar 10, 2004 | 11:16 PM
mattg's Avatar
i had the same problem recently. i'm pretty sure it's the drivers side sunroof drain.
my dealership is going to look at it on monday.
Old Mar 14, 2004 | 04:59 AM
eyesnake02's Avatar
thnx everyone I brougt it to the dealer and they gave me a Hyndai sonata loaner . and my car is been in there for about 5 days now. they said the took out my dash. they also said they are waitng for a honda autobody speacialist to look at it. so im still waiting. im pretty sure its not my sunroof thats the problem. Last time I was washing my car some water was dripping from my gas pedal so maybe it could be the winshield.
Feb 25, 2020 09:57 AM
mike from annapolis
May 7, 2017 08:21 PM
HairyMonkey019
Apr 22, 2016 10:50 PM
1lowtc
1G RDX (2007-2012)
15
Nov 19, 2015 10:52 AM
NSolace
Sep 3, 2015 08:02 PM
