car heisitates then jerks before changing gears
i was driving home in my car (99) and all of a sudden after a redlight, I noticed that the car hesitates for 4 seconds or so and then jerks before changing gears. gears 1-3 are the one with this problem while 4 is fine. what is the cause of this? easy fix?
but what do you guys think the problem is? my car is a salvage so i probably won't be covered. Going to have it checked out this weekend with my shop. Would it be bad if I contine to drive it til the weekend?
the problem seems to go away if the car is off for a while but come back after 5 minutes of driving. I can somewhat make it shift a littlebit smoother without much of the jerk by using SS and letting go of the gas when shifting. Would it be okay if I continue to drive the car like this until this weekend when I can get it checked out?
you think that would help? I had my tranny drain about 5,000 miles ago but was told that I should do it againg because it was not fully cleaned, so i was also planning to do it this weekend
Bring It To The Dealer Rite Away...ur Tranny Is Gone Haha
EDIT: oops didn know your car was a salvage but if you can upgrade your tranny that would probably be the best thing.
i checked my tranny oil and found out that I barely had any oil. I just filled it up right now. But the problem I had seem non existent this morning. so what is going on?
Comptech Freak
![ugh](https://acurazine.com/forums/images/smilies/ugh.gif)
gd luck, coz running the tranny and motor without oil is NOT funny at all, it might have caused permanant damage to the engine/tranny
i dunno if it works, but if the tranny is slipping you can try some LUCAS mixed into the ATF so it will help
NiGhT rIdEr
but the weird thing is is that 5000 miles ago I had my tranny drained and refilled with about 3qt, why is the oil so low now?
after driving 50 miles the problem came back with check enging and tcs light. Luckily I was close to my mechanic's shop and had it checked out. One of the seal was all worn out so he thinks that cause the leak. When we got it scanned, it said something about clutch problme. That is the same problem I had when I first got the car and made me fail my smog test. But that problem went away after the tranny got drained and refill. So I hope that this will go away after the seal is replace and monitorig oil level for a while.
but the problem went away after i got the tranny drained and filled again, so did the check engine and everything else. Tranny shift normal now, just need to get that seal replaced
sounds exactly like what happened to my 99. The tcs and check engines lights would come and go every reset and tranny fluid change.. i tried smoothing it out with SS mode and it still came back after a few hundred miles.. then i checked the tranny fluiid it was barely there, so i refilled it and after another hundred miles it was all gone. i brought it to dealer and they changed my tranny for me.. but guess what? after 6000 miles my car is doing this again. so im gonna be seeing my third tranny in about a week. i have 67k on my car. good luck with yours
your on your third tranny already? I would think that after one tranny it would be fine, since it is not prone to failure like the 00+ The prob\lem seems to go and come back still now. If this contines I will probably have to get it rebuilt. Do you know what cause our tranny to fail? I don't want to have my tranny rebuilt and have it fail again
orkoTL
4G TL Problems & Fixes
107
09-28-2017 09:12 AM
