Car feels sluggish
NBP and lovin it
Car feels sluggish
It seems like my 02TL-S isnt preforming like it used to. It almost feels like it lost some power. Is there anything i should check that could cause a hp drop. Something that might of broke or something. Im taking my car in for a checkup tomorrow for the tranny so if theres anything else i should have them look at that might cause this, i would be very grateful.
Dragging knees in
1. Air filter -- make sure it's not dirty to a point of being clogged. Reduced airflow will definitely kill performance and gas mileage.
2. IMRC -- Intake Manifold Runner Control; check to make sure it's working properly. If it's not, then it's killing the power.
3. Hook it up a scanner if you have access to one, and just see if the car's functioning right.
4. Reset the PCM -- Unplug the battery overnight and reconnect in the morning (at least for half an hour, if you can't leave it overnight). Have your radio security code handy.
hate to crash your thread but i wa wondering, i have an 02 type s as well, and when im in sport shift mode and about to slow down in like 2nd gear (release the gas), the car kind kicks forward and back... is this anything bad? thanks
Liquid Ice
Originally Posted by big mike 13
how do u go about checking that??
For more info on checking the IMRC check these two links:
Acura CL FAQ
Acura CL IMRC Video
Dragging knees in
If not much, then it's normal. If you're holding a gear in the upper RPM band and let go of gas, then it happens because of the difference between the speed at which the engine's spinning, and at which the transmission is spinning. Depending on the amount of torque and the RPM, the car can rock back and forth a lot or just a little bit.
Liquid Ice
Originally Posted by darkfox12
how come i cant make the video work, says something bout not having the right stuff.
divac
08-29-2018 10:13 AM
