cannot remove shift knob!!
I just bought an OEM wood shift knob for around $20 shipped on ebay but can't remove my current one. I managed to turn it like 2 degrees counterclockwise but it just won't budge. I know that it can be removed just by turning, but it seems like 8 years of staying in one position "solidified" it.
Do you have any tips? Is my only hope getting a stronger person to help me turn?
What you got to do is hold the shift knob then twist only the metal ring until it screws off. it will expose an allen screw. then undo the screw and then unscrew the knob. nobody seems to know about the allen screw thats what keeps the knob from coming off. BTW it took me three weeks with a loose knob to figure this out way back when so i hope it helps
99-01 TL knobs are held on w/ an allen scew?
Interesting...
If that's true, I guess Acura realized it was overkill, as my 03 is PLENTY sturdy lol. Takes quite a turn to get it lose. No silly screws needed just a lot of threads.
Interesting...If that's true, I guess Acura realized it was overkill, as my 03 is PLENTY sturdy lol. Takes quite a turn to get it lose. No silly screws needed just a lot of threads.
Originally Posted by fsttyms1
Just grab hold of it with both hands and twist. There is nothing holding it. Its just screwed on
When I was taking the sticker looking thing off my shift plate in my 1st gen the shift knob wouldn't move but then after a while of turning it slowly and loosing it a little at a time it finally came off and now it comes off whenever I need it to.
its possible......try using an old wood clamp. the ones with two rods you turn thats what i use.
link to pic of clamp
http://www1.istockphoto.com/file_thu...wood_clamp.jpg
Originally Posted by 03aspec
go to the gym inject some steriods..then come back riped as shit and a pull that sucker right off
Interesting...
Interesting...
just think of something that really pisses you off (my wife) and twist like a maniac. thats what i did when she spilled something all over the shifter and i had to remover everything to clean it.
cannot remove it no matter how hard i try, im guessing it's rusted inside or something. anything i can spray inside there to make it looser? maybe hotter temperatures will make it easier to remove?
i tried to use a makeshift clamp but even that didn't work.
is my knob permanently stuck, or would a stronger person be the solution?
Originally Posted by onsknth
STRAP WRENCH!
Right tool for the job.
enjoy:
sure, i'll create the "Wood Steering wheel for co1063" fund right away and we can all donate.
only $500 to go!
only $500 to go!you can check ebay for cheaper...i got mine from acura of escondido (i think)
