Can I put mid-grade in a TL Type S?
I'm new here so I don't know if this has been discussed before. Is there any reason I cannot put mid-grade fuel in a 2001 Acura Type S? Or for that matter, low grade fuel? I don't "race" the vehicle at all and drive most of the time no more than 65MPH or so. I don't rev the engine and have never red-lined it. What impact would lower grade fuel have on the engine?
Peter
Peter
Re: Can I put mid-grade in a TL Type S?
Peter
Peter
I would not recommend any fuel that is lower than 91 octane. Is not a question about "race" or "not race", it is about the way the engine was designed for high compression ratio. If you use anything lower than 91, you will get "ping"s which is really bad for the engine.
Hope this helps.
Cheers !!!
I would do what the manual says. It doesn't save u that much money in the end, only about $3 per full tank. I know with the sky rocketing gas prices in the past 2 wks, it looks bad.
Re: 2001 TLS???
Originally posted by Hangman
2001 TL-S???
2001 TL-S???
You know if you have an '01 TL-S all you got was the badge and nothing else right?
6G TLX-S
Re: Re: Can I put mid-grade in a TL Type S?
Originally posted by drcookie
Welcome on board !!!![Big Grin](https://acurazine.com/forums/images/smilies/biggrin.gif)
Hope this helps.
Cheers !!!
Hope this helps.
Cheers !!!
handsom-hustla
11-13-2015 05:04 PM
sockr1
10-01-2015 01:31 AM
