Can a 99 tranny hold 300 lbs torque?
time to ask the gurus of acurazine their opinions...i have a 99 tl that comes w the factory oil cooler...my question is to u all now is if upgrade the oil cooler n switch to motul or eneos tranny fluid a long w a engine damper, do you guys think i will be able to hold 300 n/a pound feet of torque?...if u guys think thats that enough to avoid breaking the tranny...please give ur opinions...hoping some a little brainstorming will lead to a solution
i thought oils like motul n eneos would increase the transmissions longevity...making lit ast longer? thats y companies like royal purple come out w oils that protect better than factory?
Received 1,080 Likes
The 4-speed in the 99 did not have the clutch pack issue like the 5-speed.
Stick with Honda Z1 fluid. Never heard anyone having a "fluid" problem running OEM fluid.
it cant be a bad thing to upgrade the oil n the size of the cooler...i just want to kno if anyone can recommend anythin else for added strength n durability...please guys im just tryin to brainstorm...people w tranny expertise ur help will be very much appreciated...thank you
B A N N E D
but yes, an additional cooler is mandatory, if wanting to put additional power through the tranny, the additional heat from the added power will kill the tranny sooner if that extra heat is not gottin rid of
Explain to me how you plan on getting 300 n.a. ft/lbs of torque out of your motor.
And like others said, Fluid isnt the problem with the trans. GETTING fluid to the correct parts is the problem. Most other fluids like stated above dont have the same anti foaming properties that the honda design needs and could cause more damage than good. Amsoil may be the only fluid i would try if i were to not put honda fluid in.
B A N N E D
Thread Police Chief
if all you're getting is 300lbs after "building" an engine for it, you just wasted time and money.
The only way you're going to get around 300lbs torque NA with a base 3.2 is nitrous, unless you have gobs of money to waste developing your own parts. 3.5 type-S builds with 11:1 don't even break 300lb/ft of torque.
B A N N E D
![Kiss Ass](https://acurazine.com/forums/images/smilies/kissass.gif)
btw: Rajca was doing like a 150 shot on a completely stock engine, so basically 300 ft lbs of torgue being produced
Thread Police Chief
never said that you have to build an engine for it, if all your going for is 300 ft lbs of torque, the stock engine should suffice with the correct tuning and such, so
:dick:
Head over to v6 performance and wise yourself on these engines some.
btw: what Rajca was doing was playing chicken with his engine, even more his tranny. Ever tried to "tune" an engine with nitrous? Try that with our ECU, and tell me what happens. Or go out and spend $1200 on an AEM standalone, and cry when it wont tune correctly for nitrous, again.
Hugs from the ":dick:"
B A N N E D
Typical forum troll posting "tuning" posts like that's always the answer. Its not, this isn't a B18 forum, we have J's.
![Ass](https://acurazine.com/forums/images/smilies/ass.gif)
and yes rajca was playing chicken with his engine, but he also did not really care if he blew it, it was going to be rebuilt anyways, so might as well see what the motor could take
Thread Police Chief
Exactly he didn't care. this guy seems to.
"bigger engine"?...sigh. Back to this tuning thing that you misunderstood. HOW DO YOU PLAN TO TUNE A J SERIES ECU CORRECTLY FOR NITROUS?
"...omg...I'm running ultra lean. Shit, I can't turn my trim up enough! Damnit...detonation!... But at least the tranny is ok!"
Have fun with this thread, point the guy to your tuning guides after he reveals his plan for 300NA torque. I want 330NA HP from a base 3.2 Also.
-PS: I know nothing about engines or transmissions.
![Wave](https://acurazine.com/forums/images/smilies/wave.gif)
B A N N E D
-PS: I know nothing about engines or transmissions.![Wave](https://acurazine.com/forums/images/smilies/wave.gif)
Thread Police Chief
Last time...how exactly would YOU be planning on tuning this? Show me your retarding techniques that only activate when spraying. Oh yah, we're still using a J series ECU here.
B A N N E D
AEM FIC, when the nitrous is armed, the fic will be on it's secondary map (arming switch will activate the second map at the same time, so no "forgeting" to activate it)(fic will be controlling a solid state relay btw, so switching time will not be an issue), pulling timing when it is spraying (you can pick exactly where it will be pulling timing, also you can pull different amounts depending on the rpm/load and so on, if have a desire too
I need 2 more gears
6 speed tranny
Type S block
3.5 lower end
all the bolt on's
Port matched PnP entire intake system
Extra engine bracing (ingalls possibly developing something for us)
Stand Alone EM- tuned right
Maybe you'd hit 300, but still a long shot. For cheap torquey speed get an 02 Camaro SS w/6spd or Trans AM WS6 and get ripped into the back of the seat.
Type S block
3.5 lower end
all the bolt on's
B A N N E D
6 speed tranny
Type S block
3.5 lower end
all the bolt on's
Type S block
3.5 lower end
all the bolt on's
![Teef](https://acurazine.com/forums/images/smilies/teef.gif)
![Nod](https://acurazine.com/forums/images/smilies/nod.gif)
Thanks guys for all the help about tranny fluids and explain in detail y the factory oil is better. i really appreciate it. As for how am i goin to pull off 300lbs of torque im leaving the lid on that one for now. lets just say P2R is a major part of my build so all the credit will be goin to his genius set up. When it is complete i will let the cat out of the bag
besides upgrading the cooler n running factory honda atf fluid n keeping a eye on the tranny fluid. do you guys have anymore recommendations?
thats words of wisdom....what about when i do the rebuild is there anythin i upgrade during that?
B A N N E D
but anyways a big one will be stonger clutch materials to start with, and opening up passages and such so the fluid can flow faster (and clutches engage faster), and little things like that, only thing i see is that you will be more of a pioneer in building the auto to take some power, so you might blow a few trannies in the process, while trying to find out what is needed to make it last (so might cost some $$$)
but GL
edit: also like i bought my 03 (so the
![Sad](https://acurazine.com/forums/images/smilies/sad.gif)
its one thing i love about this forum is how you guys stray completely from the topic. if i didnt have a plan to make 300lbs of torque would i be worried about the tranny holding. dont try to analyze how am i goin to make that just stick to question at hand. this thread is not about asking how to make 300lbs of torque.
YOU asked a question about fluid, and also put in the # 300 n.a torque. I simply asked how YOU planned on getting that number na because i was wondering if someone were pulling unknown numbers out of their butt. It didnt stray from the topic, but if someone makes a statement/claim like you did there are going to be people who are going to ask what i did. I was also involved on stating info on the fluid so Relax.
Pham Alvan
03-16-2016 09:17 AM
