camber kit ???
camber kit ???
Hi, does anyone know if they make a camber kit for the 99 up TL. Because mine is outrageuos. I've only had the TL for 4 months 9 6,000 miles) and in about a month i'm gonna need my third set of tires. if anyone knows please write who makes it and how much. Thank you.
silver 99 TL
Drop zone coil-overs
AEM short ram
silver 99 TL
AEM short ram
Retired MOD
1 Post
Try an alignment in the front; they could adjust the camber to certain degree.
Here is the link for some kits: Click here
<FONT COLOR="#800080" SIZE="1" FACE="Verdana, Arial">[This message has been edited by Bitium on June 11, 2001 @ ]</font>
You waited till your third set of tires to do some about your negative camber??
Yeah, snook sells the camber correction kit for eibach and ingalls. Follow the link Bitium posted above. I don't know how *slammed* your ride is but you might want to find out how many degrees you have to correct so you can buy the correct kit.
To do this, you'd have to take your car into the alignment shop and have them print out how many degrees your cambers are off by. Buy the camber kit to correct the amount of degrees that you're off by according to the print out and install the kit. Bring the car back to the alignment shop and have them do the alignment w/ the kit on.
Y2K SiLVeR TL, non-navi
SLVR TL Homepage Last updated 6/9/01
MrHeeltoe
20
02-23-2023 01:54 PM
MrHeeltoe
09-29-2015 10:43 PM
MrHeeltoe
09-28-2015 05:43 PM
