Camber adjuster
![Post](https://acurazine.com/forums/images/icons/icon1.gif)
I was on the Comptech website as I am interested in some sway bars for my TL. On the products listed available for the TL suspension was the camber adjuster. Does anyone know what this is and what it does. Does it offer any performance enhancements? I will apologize ahead of time as I am not very mechanically enclined. Thanks for any info.
Seadog drives:
2000 TL non nav
Taffeta White
Seadog drives:
2000 TL non nav
Taffeta White
Retired MOD
1 Post
No peformance gain. It will just ajust your camber. If your wheels are like this / \ after springs you could make them like this | | with the camber kit. That's all, just better tire life.
In short, you won't need camber adjuster (alignment) kit unless you lowered your car + the cambers are too negative to adjust to within factory specs.
When you lower your car, you will have negative camber. This will cause your tires to wear out unevenly by wearing out the inner side more. Consider the alignment kit only if regular wheel alignment can not fix the negative camber.
Y2K SiLVeR TL, non-navi
SLVR TL Homepage Last updated 6/9/01
emailnatec
29
09-28-2018 04:27 PM
lanechanger
10-13-2015 10:56 AM
