Calling all 2gen tl with projectors
I'm too lazy to take photos at the moment, but I'll link to the projectors and ballast/bulb kit that I fit into my headlights. The process was quite a bit easier than I had anticipated. The projectors fit perfectly into the pre existing bulb holes in the headlights. I only needed to file down a tab on the headlight reflector assembly that's used to hold the original bulb retainer clip.
With that HID kit, you may want to use relays. Every now and then I have to flick my lights off and back on again when the drivers side light doesn't come on. I suspect that the inrush current for these ballasts is too much for the stock headlight wiring. Anyway, this combo gives me a vastly improved light output with a nice cutoff line.
^ Yeah Photos would be great! those mini Projectors work nicely (By some Reviewer Video) and I figure it out that you can wire the High Part of the Bixenon to our existing High Beam for double High Beams.
I was planning on getting the e46 shroud but didn't know which one. As of now I have the mini d2s 3.0 projector. Has anyone use the e46 shroud, if so should I use the regular or extended version?
Here are the projectors that I used and
here is the HID kit I used.
I am curious, where did you put the shroud on the HiBeam area?
08_UA7_Gr33k
02-11-2016 02:17 PM
