Caliper piston help
Caliper piston help
Hey I recently purchased new pads and rotors so to save myself the labor fees I figured I would do it myself . I'm having a lot of trouble with the back piston, I tried pushing it in didn't work, I did some reading found out I had to screw it in, and I went to buy the cube tool and there is no grooves inside or anywhere on the piston. It's a 2002 TLS. Can someone help me out and tell me what is going wrong ? Is it possible the person before me put on a different caliper ? Any advice or tips will be very much appreciated thanks.
WoodGrainTLS (07-26-2012)
it doesnt screw in
it pushes in like the others
rears are known to go bad as old fluid cruds them up
try opening the bleeder valve 1/4 turn and piston will push right in if all is good inside
Plan on flushing brake fluid with any brake work
Your rear ones needed replacing? I was fine with just doing my fronts recently. They do a majority of the braking anyway, no?
Yeah i heard that it most likely went bad, i tried but it wouldnt budge, also while it was on a jack i turned the wheel and pressed on the brakes to see if it would stop the tire and it didnt, i believe the caliper is completely shot. Any one know of any spot where i can get a good price on a oem caliper?
![Unhappy](https://acurazine.com/forums/images/icons/icon9.gif)
rebuilt unit from any parts store
replace both rears and inspect fronts
SidhuSaaB
05-30-2020 12:40 AM
acuratl26
04-23-2020 07:30 PM
08_UA7_Gr33k
02-11-2016 02:17 PM
