CAI vs Short Ram
Old May 8, 2001 | 08:28 PM
Guest
Guest
Posts: n/a
Post CAI vs Short Ram
I have heard that there is danger of water getting into the engine using a CAI which can be avoided using a Short Ram. Is there a significant performance difference between the Cold Air Intake vs the Short Ram style intakes?
Old May 9, 2001 | 09:28 AM
bahreeTL's Avatar
Post
there is a danger of getting water in the intake. i've driven through big puddles with no problems, but you shouldn't be driving in 2-3 feet deep water anyway. if you're still paranoid, then you can get the AEM bypass valve if you're getting an AEM intake. i think someone said the valves are being recalled, but you should check on it. the differences in gains probably wouldn't be noticable until you're at higher speeds when the cold air rushes into the CAI.
<FONT COLOR="#800080" SIZE="1" FACE="Verdana, Arial">[This message has been edited by bahreeTL on May 09, 2001 @ ]</font>
Old May 9, 2001 | 09:49 AM
juniorbean's Avatar
Cool
If you have a TL-S (which I'm assuming you do since you're in the TL-S forum ) you can get an intake from AEM or Xephyr Performance. Now, I know you're saying you've never heard of Xephyr. He's a guy from the CL forum who started his own company. Check out his site ( www.xephyrperformance.com ). The numbers are pretty much even with AEM, but the intake, with the by-pass valve already installed, costs only $185 plus shipping. That's close to $100 less then the AEM. If you decide to go the AEM route, www.autocarparts.com is the place to go. All in all, CAI's are better. You will get a lot better perfomance with a CAI....
1998 Acura CL 3.0 (Iced Blue) ** Some mods, but who cares,
I want a Type-S... (CL or TL)!!
Moderator - 1st Gen Forum @ www.acura-cl.com
<FONT COLOR="#800080" SIZE="1" FACE="Verdana, Arial">[This message has been edited by juniorbean on May 09, 2001 @ ]</font>
Jul 16, 2017 07:33 AM
swany0095
2G TSX Performance Parts & Modifications
Oct 7, 2015 02:18 PM
h22lude
Sep 27, 2015 06:22 PM
AcuraKidd
Sep 25, 2015 11:18 PM
