buying 1999 tl 3.2
buying 1999 tl 3.2
I'm looking at a 1999 tl with about 60,000 miles (no navigation system) that I'm considering buying and could use any advice that anyone might have.
Car drives strong and straight. Thought I noticed a slight pulsating once or twice in brakes?.
Is there anything to lookout for? Does a timing belt need to be changed at anypoint?
As far as I can tell the car is in pretty good shape. Engine seems strong. It needs to be detailed, needs new tires soon, and the door cover for the cd holder (I think that is what is just above the radio) is missing.
Any direction / advice anyone can give would be great. Ny the way the asking price is $11,900.
Thanks,
Mike.
Thanks,
Mike.
third genenration Tls have tranny problems....so better be careful if you wanna keep it for long......however seems like 99 tl is quite reliable.....look at the active poll i am running to see how reliable it is...i have 99 tl and kind of worried about its reliability
I need 2 more gears
99-03 is 2gen TL not 3rd gen. I would recommend a 99 over a 00-03 anyday. tranny's are much less likely to go bad. I have 117k+ on original tranny and it shifts fine no slippage. Engine is very strong. 11,900.00 for 60k is not bad, but you might better deals if you look hard enough. pulsating in brakes is normal for ABS systems, is it a rough pulse?
i think fymstm mentioned in his post that he is on 4th tranny
Originally Posted by PenancE
i still got orig belts on my 99, but fymstm, sry for name lol, he has his and hes at like 190+!!!
05 C230K & 09 135i 6MT
And
Transmissions are ALL poorly designed 99-03. There are fewer failures in 99 models because there are less of them.. 1 year model versus 4.
I had a '99 until I traded for the '05. 1999 TLs are great. I ad 70k on it ans wish I could have afforded to keep both, but the Nav system in the '05 won out. The pulsing in the brakes is probably just the rotors, so a brake job is probably needed sometime soon. As far as the timing belt I don't think it's due until over 100K. 11,500 is a little steep, but if you like the car go for it.
WNC Real Estate Sales99TL
Bought mine 99 Navi with 38,900 on it for $11,000 in mint condition. This was in Sept. 05. I'd try to deal with them especially with the brake issue. It will cost you a lot if you don't replace the rotors and pads yourself.
The '99s have a 4 speed transmission while the '00 - '03 have a 5 speed transmission. The 5 speed transmission does have more problems than the 4 speed and it's not simply because there are more cars with the 5 speed.
thanks
Thanks for all the advice. A little confused on the tranny situation. Not sure how worried I should be about failure. Does the 100,000 mile warranty transfer to a second owner?
As for the price, looking in the classifieds on-line and print $11,900 for a 99' with 59,000 miles didn't seem to out of line, am I looking in the wrong place? Kelly Blue book has a private value for less but a retail price for more???
I need 2 more gears
honestly I wouldn't worry too much about tranny failure on a 99 I have 117k+ on my original tranny and I have mods and drive it hard. It still shifts fine and as I have said before never slips. Look on www.autotrader.com for TL's in your area. 59k is very mileage for a 99. Also make sure regular maintenance has been done, but these cars don't require much maintenance. Good luck in your search, when you find your TL, I'm sure you will love it.
BTW, kris hasn't replaced his timing belt yet.
Originally Posted by MikePA
This is NOT true. You'd think with 1,910 posts you'd know the reason.
What some people on this board fail to realize is that the 99's transmission is also poorly designed.
Did I say it was well designed? No, I didn't. I am not aware of anyone on this board (except noobs) who fail to realize the '99 also has a poorly designed tranny. I said it fails less frequently than the 00 - 03 transmissions and not just because there are fewer of them to fail. Given the choice, I'd buy a 4 speed '99 over a 5 speed '00 - '03.
For some of us, the added feature content (and on S versions, performance) of the 2002-2003 models make it worth the risk with the extended warranty.
1999 TL owner here, around 90,000 miles I bring my TL in for the scheduled service, supposedly everything is fine, about 2,000 miles later my transmission starts acting a little wierd - just sluggish. A little after 100,000 miles the tranny goes completely, acura wouldn't cover it under warranty, I believe they wanted 4 or 5K just to put in a refurbished tranny.
From what I understand, acura still has not fixed the 2nd gear clutch pack issue. I don't follow this board much anymore so I might be wrong, but search is your friend.
Not trying to flame, but I would NOT recommend a 99. Your cd player won't play burned cds, tranny still has a decent chance of failing, stock rotors will warp almost instantly (it feels like). I'd search the boards for info on local dealers - a good dealer might make it worth it, but the ones around here suck. I'm still driving my TL, but I can't recommend that anyone else buy one, especially if you can get a gs 300 or such for not too much more (although it might have higher miles).
navtool.com
31
11-16-2015 08:30 PM
navtool.com
09-25-2015 05:15 PM
