Butterfly Valve...
Old 08-07-2002 | 12:45 AM
Butterfly Valve...
any one know where the butterfly Valve is located on out TL's?? they say it only opens at a certian rmp range? is that true?
Old 08-07-2002 | 01:24 AM
gohawks63's Avatar
The term "butterfly" was last used on carburated (sp?) cars. The TL is fuel injected and does not have a carburetor.
Are you referring to the VTEC actuator? The VTEC actuator kicks in around 4500 rpm for '00'-'01 TLs, and TL-P (4800 for TL-S).
If so, do a search, I believe there have been a few thrads on this.
Old 08-07-2002 | 02:44 AM
asiankidd's Avatar
hes talking about the intake pleum which opens at 3800 its internal but you can see the actuator between the engine and the stock strut bar
Old 08-07-2002 | 11:05 AM
T Ho's Avatar
The butterfly is inside the intake manifold. It's purpose is to shorten intake runner length above 3800rpm. This increases available top end power.
Shorter intake runners provide more top end power, at the expense of low end torque, which is why it's done this way. With our intake, we get both, which works well to provide torque for 5th gear, as well as rocket shots to 7000rpm.
Incidentally, it's the opposite for exhaust- Longer header downpipes (prior to joining) provide more top end power, at the expense of low end torque.
Old 08-08-2002 | 12:50 AM
then is it wise to replace the intake with the AEM CAI??
Old 08-08-2002 | 10:45 AM
RAdams's Avatar
The dual-stage intake system is not part of the intake tube itself, but rather part of the intake manifold, therefore using an AEM or Injen CAI won't affect its operation.
Old 08-08-2002 | 11:27 AM
bigman's Avatar
'Big Daddy Diggler'
replacing the intake with a higher flowing one will increase the ammount air, therefore increasing the air fuel mixture creating some hp and tq gains. It wont effect the intakes operation negatively.
cycdaniel
12-17-2019 10:58 AM
09-17-2015 09:01 PM
09-17-2015 08:57 PM
09-14-2015 10:48 AM
Quick Reply: Butterfly Valve...
