Bumper question.
Bumper question.
If you have read my previous thread.. i ran over something going at like 60 mph last nite and i juss checked it this mornings... seems like the plastic piece that goes all across the bottom of ur bumper has been torn off... to clarify this picture for u guys.. if u stand by my passenger door and look at the wheel, u can see the winsheild washer fluid and everything.... as well as the mudguard area.. that plastic was torn off too... u can see my wires and stuff if u were to bend down a bit to look.. Would i be able to replace that piece from the dealer or do i have to go TL hunting j/k....
Former Sponsor
I'd get one from the dealership. It's called a fender well skirt. Mine was loose on that side when we picked it up. It needs to be replaced also. You will also need to pull out all the bolts that used to hold the old one on. There should be about 10 bolts, I think, Maybe more. Jack that side of the car up and remove the wheel. That will make your job alot easier.
Good luck man! Have fun. And watch out for those damn Possum!!
Yes, you can get both the fender well skirtings and the center underskirt piece. I don't believe they are too expensive--around $50 I want to say, but you may have to purchase the bolts to go with it for a few dollars.
Originally Posted by bkzjimmy
if ur goin tl hunting...stay away from my block! lol
have thought bout it but was like.... nehhhh.. how much can those wheel well thingies cost... now if my Hids were stolen then u should find a garage for ur car
quanaman
01-09-2023 07:33 PM
08_UA7_Gr33k
02-11-2016 02:17 PM
