Which bulbs do i need for my highbeam?
you can remove the ps pump i believe it is i cant remember, but it just slides up let it hang but make sure there is no pressure on there and then you can get access to the bulb, but most likely u will not need a phillips screwdriver just turn it counter clockwise and it will come out, it might be tight at first just go back and forth till it comes loose but dont break it! very very easy and then after just slide the ps pump back in, no wait its ps or rad fluid! anyways hope that helps!
ripit
09-26-2015 06:19 PM
