Broken Stabilizer Link and Tie Rod End Lose
Hi All :
I went to replace the divers side brake pads and discovered a broken stabilizer link and excessive play in the wheel accompanied by a clicking sound where to tie rod end meets the lower control arm. I've looked through all the previous postings for these two topics and still have a few questions.
Tie Rod Ends - Were is this part located in the parts catalog ? I looked under "Knuckle" and "Front Lower Arm" and can't seem to find it.
Stabilizer Links - Where is the "allen" screw ? Mine have a plastic cover with little four bumps. Do you break that off and find the screw head underneath ?
Also, anyone got any tricks to loosen these nuts and bolts ? I hate front end work, it take hours and hours to remove a few nuts and bolt and ten minutes to install the new part.
Thanks all who reply.
smarty
smarty
Oh, and an extra tip for suspension work (and this removal specifically)
Jack up the whole front of car and not the side...take load off BOTH sides of the stabilizer bar by doing this otherwise you'll be trying to hammer etc to get the stupid threads pushed thru (once nut removed)...when you have the front jacked up you can do it all by hand very easily.
Easy fix...20 minutes, tops.
Thanks rockstar :
I got the allen key location, thanks very much. I don't know why it didn't occur to me to look at the bottom of the bolt, but it didn't.....
I guess that's why we have this forum.....
Not a problem, man...hey, something is only obvious once you've done it already! lol...
Good luck man, should be an easy fix...the sucky part is that part is expensive...I think $45 or so per side per front/rear. I stripped one once
I should have checked the forums first!
Steering : Tie Rod End
MOOG Part # ES3490
Frt Strg; Outer; LH
$26.79
Suspension : Stabilizer Bar Link
MOOG Part # K90341
Frt Susp; LH
$16.21
Plus $8.34 shipping.
Not too bad.....I'd hate to see what the Stealership would charge ?
Oh, and I found the tie rod end in the parts cataloge.....it's under "P.S. Gearbox"
MOOG Part # ES3490
Frt Strg; Outer; LH
$26.79
MOOG Part # K90341
Frt Susp; LH
$16.21
If I'm very careful and measure the tie rod accurately, do I really need a wheel alignment ?
Is tire wear the only way to spot bad alignment ?
Thanks again to all who replied
you won't be able to get it close enough, once it's installed get the toe adjusted. And they have gauges that tell you how bad your alignment is so no need to wait and see the tire wear. You also should have the rest of the front end checked out too.
MOOG Part # ES3490
Frt Strg; Outer; LH
$26.79
MOOG Part # K90341
Frt Susp; LH
$16.21
MOOG Part # ES3490
Frt Strg; Outer; LH
$26.79
MOOG Part # K90341
Frt Susp; LH
$16.21
I payed $58 for both links straight from the dealer.. its better having oem parts..
However, in this case there was allot of posts relating to the OEM links being generally weak and the Moog links being significantly stronger. Coupled with the fact that its been broken for I don't how long with, no apparent affect on the car's handling, I think I'm safe with this deviation.
certain OE parts or fluids are good- thats true
others are what acura could buy a gozillion of.. for the cheapest price
in the case of end links- there is a problem with their failure
Moog brand is well known and trusted maker of suspension-steering parts, and for their price they cant be beat
no way to get the alignment perfect by your hand
Measure-count exposed thread on old unit and set new one the same
That will get you to the alignment shop- safe enough
ways to tell alignment is off- the car wanders or pulls or drifts
Most of us need one once a year- and balance the tires!
speedbumps, potholes, and general freeway use all mess things up bad
you forget how smooth the TL was --then suddenly its like a new car again
that piece you are replacing with the threads on it- thats where the adjustment is made
for toe,
dont let them bs you about shims for the rear etc, we dont have--
get a `4 wheel thrust alignment`
for toe,
I've always thought so to.
allright!! something we essentially agree on!!
dealer parts for the TL I would buy:
ps fluid
but get it for less at the import/performance store
ps fluid
my front passenger end link went off as well... were gonna do a diy tomorrow.. not me actually itll be my friend.. ill try to post some pics and info up.. i had the same issue on my right rear as well.
marcelft
07-10-2018 06:17 PM
09-17-2015 09:01 PM
