broke a wheel stud...advice needed
Old May 25, 2003 | 10:52 PM
asiankidd's Avatar
hey guys i know this is a real rear case but i broke a wheel stud, and im trying to replace it, i got the rotor off and everything but i can get the other hub with the studs off. its hard and complicated to explain, but does anyone have any idead how to take it off, or who has done it before, if you could can you please tell me how i woudl GREATLY APPRECIATE IT..thanks
JON
Old May 25, 2003 | 11:57 PM
StanMan's Avatar
if you have the rotor off the car/axle, you simply knock the broken stud inward and then pull them out of the circular openings. the reverse is to replace and use can use a lugnut to properly seat the new stud.
Old May 26, 2003 | 01:31 AM
hellas's Avatar
the tl doesnt have circular openings on the knuckle.
if its the front, the knuckle has to come off and the hub pressed out.
if its the rear the hub just pulls out
Old May 26, 2003 | 04:07 AM
asiankidd's Avatar
man i try to press the hub out but its connected to the main bearing and chances are pulling it can damage the man bearing so i ghetto it and dremel out the old studs, and modify the new studs to fit, POS old studs, i never had so many problems with my tl all at once.....i need to vent guys so here are my problems for the WEEKEND!!!
rattling exhaust (put back resonator dunno why perhaps ****ed up air flow now)
new wheels came in but broke stud off when taking off old lugs cus stoopid ass person impact it in wrong and fused it together....so while taking it off it broke....
then while i was driving on 4 lugs...for some reason the other 4 decided to get ****ed up when i was trying to fix the one bad one.... so now i have 5 bad studs!!! ahhh, on top of that CHECK ENGINE LIGHT WENT ON reads p0141 malfunction o2 sensor...**** headers been giving me so much trouble leaky install, no gaskets, ****ed up jet hot coating, now a fried o2 sensor....i dunnno but all i know is that this car is going back to stock as soon as possible...
JON
Feb 25, 2020 09:57 AM
cammy5
Sep 4, 2015 11:26 PM
nuldabz
Sep 3, 2015 05:49 PM
MyKids&Cars
Sep 2, 2015 12:03 AM
blownby
Aug 31, 2015 12:44 PM
