brake and tranny fluid
Retired MOD
1 Post
Re: brake and tranny fluid
Originally posted by ABLUETYPES78
at what mileage should you replace your brake fliuid and tranny fluid?? i have a 2k2 tl-s 15k
![Question](https://acurazine.com/forums/images/icons/icon5.gif)
does anyone know if tl-s has a valve body....in other words... is there a filter that has to be changed besides tranny fluid?
Not a Blowhole
No filter you can access - it is internal.
I would change brake fluid every two years - regardless of mileage. Brake fluid deteriorates not from use, but from the fact that it is hydrophilic. Just sitting around, it picks up water from the vapor in the air.
If you are lazy and or cheap, here is a tip. Get a basting tool, and remove half a pint from the master cylinder each month. Brake fluid slowly ciculates through the system, and this will continuously remove and replenish the fluid.
I still recommend a proper drain/fill/blled every 2 years - that is what I do with all my cars, and never have brake problems.
ABS units are very expensive to replace, so this is cheap insurance.
The tranny? Every year. It is so easy to do, and these trannies have been very weak points.
Not a Blowhole
yea i changed my tranny fluid real easy......brakes are next thanks
It is also a good idea to "cycle" the ABS once a month - find a spot with some loose gravel, and stand on the brakes. Keeps the valves moving and limber.
Stick with the Acura brake fluid - DOT 3 and DOT 4 are slightly different in formulation, and it is best to stick with what the mfr recommends when it comes to brakes.
If you autocross, you will need to replace/bleed the brake fluid every month or so.
In that case, consider ATE brake fluid - it comes in amber and blue colors. Alternately, switch from amber to blue - when the color changes as you are blleding, you know you have replaced the fluid. Saves some time and $$ if you bleed brakes a lot. One caution: the blue dye can slightly color the plastic reservoir on some cars, so caveat emptor.
SidhuSaaB
05-30-2020 12:40 AM
