Brake Lamp On --- Confused
I just put on a set of 03 tail lamps on my 99 tl and all of a sudden the brake light indicator lamp turned on.... Every bulb works; checked that twice even the twin filaments and everythin checks out and works. What could be causing this problem?
Is it the Brake Lamp indicator on ? well i used to mess with signals and stop lights and later on it gave me that warning. I think its nothin man. Probably with some bulbs going out but as you said you checked and found nothin. Then its fine, i think all we need is reseting it
Solutions in the past have been either: topping off the brake fluid reservoir to the appropriate level; exercising the brake fluid level gauge (the stryofoam part of the cap) - sometimes the contacts get dirty; or exercising the brake pedal, to get the switch exercised - one click will turn the light on, not apply brakes and be hard to notice as far as pedal position goes.
Hope those ideas help.
detailersdomain
Wash & Wax
Oct 9, 2015 10:13 PM
Eggs999bacon
Sep 24, 2015 10:08 AM
