Brake Fluid Bleeder Kit ????
Anyone know if there's a brake fluid bleeder kit out there ? I wanted to change the brake fluid but I can't seem to find a kit to do this. Any help would be appreciated
You can usually find one at an auto parts store in the tool section. Usually it is a couple of clear pieces of plastic tubing and a check valve, sometimes with different size ends. Probably 15 bucks topps. Eric.
2003 SSM TLS
A mityvac allows you to "vacuum" the fluid through the system by sucking out the bleeder valve on each caliper so you don't need a second person to keep pressure on the brake pedal while you are opening and closing the bleeder valve.
check out this, it will allow you to do it by yourself
http://www.bmw-m.net/TechProc/bleeder.htm
it works, i have made one and used it
mada51589
05-03-2022 08:54 PM
ulrblitzer
09-24-2015 07:42 PM
