Brake Caliper Bracket Mounting Bolt Size?
Old Jan 8, 2019 | 09:24 PM
2003_tl_200k+'s Avatar
Question Brake Caliper Bracket Mounting Bolt Size?
need to know the size of the caliper bracket mounting bolt
Was doing all 4 wheels pads and rotors and ended up rounding one of the rear brake caliper bracket mounting bolts does anybody know what size bolt/thread it is? I think its 14mm just don't know how long it needs to be. Can't find a replacement at any auto parts stores in my area and haven't had any luck online either. I have a snip of the part but it only has the torque spec to clarify NOT THE BOLTS FOR THE CALIPER PINS
Old Jan 8, 2019 | 09:36 PM
Look at line item #17 on the link below for its size:
https://www.oemacuraparts.com/v-2003...s--front-brake
Old Jan 8, 2019 | 09:44 PM
It says it fits the year so worth a shot thanks!
Old Jan 9, 2019 | 07:25 AM
Iggy's Avatar
This metric flanged bolt has a thread pitch of M12x1.25, and is 21 mm long (thread length, measured under the head to the end of the bolt). The entire length, including the head, is 32.2mm. The hex head requires a 17mm socket for removal/installation. The bolt grade is 10
binary_10essee
Jul 21, 2017 11:42 AM
paulmnly
Dec 1, 2014 11:53 PM
acitydweller
Oct 29, 2007 09:33 PM
