Brake bleeding issues.
Old May 22, 2018 | 11:01 PM
Cardad0325's Avatar
Please help.
so the car is a 2002 Acura tl3.2
the issue is only the LF and the RR calipers will bleed. So the car came in, and you can see where the MC was leaking into the booster.. so I replaced them and the 2 lines from the combo. Valve going to the LR&RR wheels were broke so I replaced all that went to bleed the car and only the LF and the RR calibers will bleed the other wo will not. No pressure,air,fluid nothing in the two lines . If you hold the pedal thoes two wheels you can spin ... makes no sense to me.
Old May 23, 2018 | 03:37 PM
Chojun's Avatar
So you replaced the Master Cylinder?
The calipers should be bled in the order from RF->RR->LR->LF.
You'll probably need other people around here to help you troubleshoot.
Old May 24, 2018 | 06:14 AM
08KBP_VA's Avatar
Did you bench bleed the master before installing?
Troll TL
Nov 20, 2013 10:27 PM
TRILIGHT
Aug 5, 2006 02:29 PM
Road Rage
Jul 29, 2005 01:06 PM
Allout
Sep 26, 2004 04:24 PM
haig14
Apr 2, 2004 12:57 PM
