Both lower ball joints bad after a year
I replaced my left lower ball joint Jan 2010 / 20,000 miles ago. Right side was replaced April 2010 / 12,000 ago.
After car wouldn't hold the alignments being done at a lifetime alignment shop. I took it down to a suspension shop and they're saying the left side is bad and right side is showing a good amount of wear already. They seem legit... I found play when wiggling the wheels.
Question is why have the ball joints failed so fast. How do I make them last longer? We had a rough winter and lots of potholes but the first set went 100k miles before affecting the steering and the seconds set only lasted a year. Is this typical on our cars?
The shop that did them last time put in OEM. I was thinking moogs might last longer longer? Any other brands to check out?
Are there any issues with the 2g moogs? I was reading this on the 3G https://acurazine.com/forums/3g-tl-tires-wheels-suspension-97/fyi-aftermarket-moog-balljoint-k500117-beware-805131/
Also, the shop says everything else in the suspension looks good when I asked them about the tie rods and end links. Is it worth replacing anything else while the ball joints are being done...car just turned 125k miles
yeah-faulty install can lead to early wearout
OE parts are not the greatest in most cases (except acura water pumps rock!)
mada51589
05-03-2022 08:54 PM
