bleeding brakes
Old Apr 18, 2005 | 12:28 PM
SLAMMED_WDP_TLS's Avatar
bleeding brakes
does anyone know how to properly bleed brakes and dont mind helping me with a step by step play. THANKS!
Old Apr 18, 2005 | 12:44 PM
SatinSilverTypS's Avatar
ChairmanMaoSaysRTFM
this is best done with 2 people.
with the car off, get a buddy to pump the brake pedal until it can't be pumped anymore. when he gets to this point have him keep pressure on the pedal and you turn the bleeder valve on the brake caliper with a little wrench. you will hear air and then get a shot of brake fluid in the mouth
the brake pedal should move to the floor as you relieve the pressure, but once you see fluid just close the bleeder valve.
repeat this at each front caliper to make sure there is no more air, then at the rears if you want to be thorough. i know on my ford it was enough to just do the fronts, but obviously this isn't a ford. just keep some extra brake fluid on hand.
let us know how it turns out.
SSTS
Old Apr 18, 2005 | 01:38 PM
thanks bro. Yea my homis is going to help me out with this. But we gonna do it to my girls car first since my car is in the shop. Hse has an accord so I am sure that its the same procedure. THANKS AGAIN!!!
Old Apr 18, 2005 | 02:24 PM
PeteTLS's Avatar
Don't Let The Brake Reservoir Go Dry, Or You're Just Letting Air Back In The System From The Top!!!!!
Old Apr 18, 2005 | 08:15 PM
ChairmanMaoSaysRTFM
good call. thanks for the sanity check. and no problem on the instructions. i doubt you should have any problems.
SSTS
Old Apr 19, 2005 | 01:39 AM
EOBrien's Avatar
Traditionally, it is a good practice to start with the caliper farthest from the master cylinder. Run a clear hose from the bleed screw into a clear glass bottle with some fluid so you can better gauge the quantity of the air. And, as mentioned, if you run the master cylinder dry you are hosed. Good luck!
Old Apr 19, 2005 | 05:42 AM
MikePA's Avatar
This has been discussed before...Acura's bleed sequence is not to start from the farthest from the master cylinder. I check my Service manual, but I don't take it with me when I travel.
Old Apr 19, 2005 | 10:51 AM
yunginTL's Avatar
trill recognize trill
sorry to ask but what does this exactly do? some1 wanna fill me in?
im guessin takin out brake fluids from the lines and puttin new brake fluid in?
Old Apr 19, 2005 | 11:01 AM
PeteTLS's Avatar
The hydraulic fluid in the system doesn't compress when you apply pressure, but air compresses a lot. This means that if you have air in the lines and hit the brakes, the possibility is that you'll have no brakes because the air will just 'give' instead of transferring your foot pressure to the brake pads and stopping the car. Bleeding gets the air out so that all that is in the lines is hydraulic fluid, dramtically reducing the pucker factor of foot-to-floor-cars-not-slowing-there's-a-wall-OH-CR....
Was that your question? Or did I miss something?
Old Apr 19, 2005 | 09:51 PM
Toby_TL's Avatar
If I go for brake fluid flush service.Will all my old brake fluid all out and it that include bleeing brakes to?.
Old Apr 20, 2005 | 05:55 AM
ChairmanMaoSaysRTFM
yeah it includes bleeding but it's just cheaper to bleed them yourself and just keep putting fresh fluid in the reservoir until you know you got all the old crap out. it's really not difficult to do. i recommend it as a good first project for anyone who wants to jump right in to vehicle maintenance.
SSTS
Old Apr 23, 2005 | 03:15 AM
Thanks guys, My homie and I will be tackling this project next weekend. I order some EBC greenstuff for my girls accord and for myself. My brakes are ok but hers has some air trapped in the lines so its kinda dangerous for her to drive around plus my car is in the shop anyways so I cnat work one it. But once again thanks for al lthe inputs. I will update on how we did on my girls accord first. THANKS!!!
Old Apr 23, 2005 | 04:55 AM
MikePA's Avatar
How did air get trapped in the lines?
Old Apr 23, 2005 | 07:05 AM
kabota's Avatar
heat, time, overall usage
GWEEDOspeedo
Jan 15, 2016 10:39 PM
rockyboy
Oct 2, 2015 10:45 PM
polish_pat
Sep 30, 2015 12:22 PM
27trains
4G TL Problems & Fixes
Sep 30, 2015 09:44 AM
