Big problem with the car, I hit curb
When I was in Chicago last weekend I hit a curb, well I ran onto the curb. I was kinda retarded, I was at a stop sign and turned right on to the curb which I thought was a road, the speed was really slow at about idle speed.
Could there be any damage to the car like the drive shaft, ball joint, suspension or brake, cus I climbed on to the curb.
The only abnormal behavior I think my car has right now is that the steering isn't perfectly straight and I can actually feel the power steering boost when I make tiny adjustment to the steerign angle, I think my steering wheel viberates now when I'm on the expressway, though my front tires are both at 40PSI, would that be a problem?
Please help me
I'm thinking about taking my car to the dealer and get 4 wheel alignment done, is there anything else I should look out for?
Please help me
05 Acura TL: a-spec
unless you get that alignment done for cheap cuz you know someone at the dealer, or its covered under warranty (which i doubt), I would advise a local shop?... It definitly cheaper than the dealer and its not like the only place u can take your car is to the dealer.
I got a $10 off coupon from Acura of Ann Arbor on Alignments, is it a good deal? I dont know how much it would cost, I plan on spending $60 dollars
05 Acura TL: a-spec
normally alignment is between $30 - $70 for 4-wheel alignment. If you really want to do at the dealer, then with the coupon, it will not be too bad. If Dealer costs $69, then you can look around at the private shops for $40 or $50.
checkmate...
The car is most likely fine, just get a 4-wheel alignment done.
Depending on your proximity to Windy City pedestrians when you jumped the deep-dish curb, though, your ego and pride may be shot.
We can't forgive you for being retarded. On da oder hand, if you had blamed dis all on a hot Chicagoan gurl walking down da street, causing you to gawk her way while turning da wrong way, den dat my friend woulda been a great story.
