better buy rotors???
i know most member went with rotoras or irotors, but went to ebay and saw this!!!
Gripforce F1 Brakes
About This Item
Gripforce cross-drilled and slotted rotors meet all OEM specifications and are guaranteed to fit your vehicle with your existing stock brake calipers and pads. No modification is required for these brakes to work on your vehicle.
Our rotors are cross-drilled by CNC Cadkey machines programmed to drill specifically for each application. We use the same technique and rigorously tested methods that other leading high performance brake manufactures use. The holes are drilled completely through the face of the rotor, enhancing airflow while maintaining structural integrity and perfect balance. Cross-drilling allows efficient ventilation keeping the rotors 200 degrees cooler.
Slotted lines are designed to help remove water, dirt, and brake dust buildup. The slots deglaze brake pads, improving contact between the pad and rotor. The effect overall helps achieve a shorter stopping distance and better brake response.
All Gripforce rotors are plated with a premium silver zinc to prevent rust. The zinc is electrically charged onto the rotor in chemical tanks. This method has been proven to be far superior than spray painting.
Items Included
Pair of front cross-drilled & slotted zinc plated rotors
Pair of rear cross-drilled & slotted zinc plated rotors
Optional: Add $85.00 for Street Performance Brake Pads.
Part Numbers
RXS40046
RXS40047
all this for only $133 plus shipping
Gripforce F1 Brakes
About This Item
Items Included
Part Numbers
RXS40046
RXS40047
