Best way to clean carpeting inside car?
Hi all. What do you guys use to clean the carpet inside the car? I've thought of buying one of the pro level extractors but they all seem to run about $1500. More than I want to spend. What else is there? Most home shampoo machines won't fit in the car to do the floors.
I got 99 Problems
they have this super great stuff, it is Resolve except not a spray foam it is powder no need to wet, soak let dry. just put it on and scrub with brush that it gives you and results are great. it cost like $7
What your problem is?
I just spend 30 bucks at a Mister CarWash and have those guys take out the stains... they tell you up front that they can't take out red stains.... but everything else will come out....
Originally Posted by WiLLS Type S
Or you can do it yourself...with carpet cleaner. Any of them will do.
I use HotSpot cleaner in a spray can that you can get at any supermarket; works excellent.
I've used a mix of oxy-clean and water in a spray bottle. Works great with most stains and you can localize the cleaning area.
For the mats I like to take them out and scrub them in the tub with a little tide and lots of elbow grease with a brush. Then hang dry. Vaccum it well first, to get most of the dirt out. :-)
bearingman07936
01-07-2016 03:22 PM
